64 Front suspension
64 Thunderbolt
64 Front suspension
Post by 64 Thunderbolt »
I'm looking at either staying with & lowering the stock front suspension on my 64 or going with something else. What do you all think?
I thought I saw something somewhere about a Dodge pickup front suspension.
What's the best ride & drive & handling?
What are yall's opinions?
I want to lower it whatever I use.
64 Thunderbolt Clone (in progress)
Henry J gasser
85 F350 Dually
95 Explorer
You can go with a Dodge Dakota front end - the crossmember isn't available right now though I understand.
You can go with a 03 & newer Crown Victoria swap - this will widen the track though and require modern Mustang type offset on the wheels.
You can have Sid in Oklahoma City do a drop on your front axle.
You can "flip" the front axle.
Or get mono leafs made by No Limit (get them from Flashback F 100s).
You can also do a disc brake swap on the straight axle.
I have the disc swap and the No Limit reverse eye springs myself;
http://fordtruk.com/forums/viewtopic.php?t=15942
Axle flip in this thread;
http://fordtruk.com/forums/viewtopic.php?t=19250
Disc swap;
http://fordtruk.com/forums/viewtopic.php?t=2647
Crown Vic;
http://fordtruk.com/forums/album.php?us ... &mode=list
http://fordtruk.com/forums/viewtopic.ph ... ght=#36973
Dropped Axles;
http://www.droppedaxles.com/
BTW, do you own a 64 T Bolt?
Pics are required......................
:mrgreen:
64 Thunderbolt
Greg, Thanks for all the great articles & help! I'm going to read them sometime today & figure out what I want to do.
What I have is a 64 Fairlane that I'm building into a clone. Right now I'm just collecting parts, I haven't even started tearing it down yet. It was a barn find that had been setting there for almost 15 years. My dad raced one of the Thunderbolts when they came out, that's why I'm building this.
Henry J gasser
85 F350 Dually
95 Explorer
T Bolt Clone - COOL!
Almost better than a real one - you don't have to be afraid to drive it.
Your Dad Raced T Bolts - VERY COOL!
This was at a local car show 2 years ago;
Shadow
"64"
Post by Shadow »
Hey Greg, I Was Looking Into These Mono-Leafs. They Come With Everything Needed. Also They Have 3" Or 4-1/2" Drop. Around The Same Price As Sid's Dropped Axle. To Me Getting The Drop With The New Suspension Bushings & U-Bolts Included Seems Like A Deal. What Do You Think About These?.................................................
Shadow
"64'"
Post by Shadow »
Whoop's... Helps If I Post The Link. http://www.performanceonline.com/1948-6 ... SET-17632/
Rusty 63
Post by Rusty 63 »
The thing to watch for on the drop springs is needing a notch in the frame & possible oil pan clearance issues.
64 Thunderbolt
Greg D wrote:T Bolt Clone - COOL!
Nice car!
I won't have a 427 in mine. I will be going with a 390 with 2 fours that I will try & make look as close to a 427 as I can. I can't afford a 427!
Other than that I'm going to do everything else the exact same but make it a driver!
Henry J gasser
85 F350 Dually
95 Explorer
I have the reverse eye monos on mine - 2-3 hour bolt in swap (depends on how rusty your bolts are).
I would suggest replacing the upper shackle bushings and shackles while you have it apart. If you can get them rebuild a set of F 250 shackles - the shackle plates are much thicker and makes for more stable cornering.
DO NOT leave out the little S shaped partial leaf when you install the monos - this keeps you springs from sticking in a reversed arch position.
These will give you an idea of what kind of clearance you'll have;
This is the stance I got;
225 x 60 x 15s on 7" rims on the front
275 x 60 x 15s on 8" rims on the rear
Rear spring pack was made from the stock 3/4 pack (this truck was an F 250).
That car I posted pics of isn't an original T Bolt - car was a assembled from a Fairlane 500 and a wrecked T Bolt.
Still cool though.
64 Thunderbolt
Greg, nice truck!
I'll probably go with flipping the springs as in that one article. I'm into cheap!
I'll need to figure out what I want to do with the rear. I want to lower the rear but also widden the tubs for wider wheels & tires in the rear. I have a 9 inch from out of a 79 f100 for it. That will be another post soon!
I like that low & wide look!
Henry J gasser
85 F350 Dually
95 Explorer
