I really don't want to argue the point. And, I agree, physics does not lie. However, we must ensure we are comparing apples to apples.charliemccraney wrote:A 5/16 bolt tightened to 60 inch pounds, about appropriate for a carburetor, has a clamp force of about 958lbs. If you can properly torque the bolt in an aluminum manifold without it stripping, then that single bolt can support the entire engine. I do not recommend that one bolt be used with a lift plate because the forces applied to a single bolt by the lift plate will be potentially disastrous; it will in effect be prying the head of the bolt off rather than pulling straight up and applying an even load. At 12 ftlbs, which is a common torque for a 5/16 bolt, a clamp force of about 2300lbs is applied.
I understand that it's difficult to grasp just by looking at that little bolt but physics does not lie.
Just as not all 5/16" studs are created equal; some are made from Grade 2 stock and those made from Grade 8 stock which present different stud strength ratings. A similar arguement can be posted regarding the differences in the clamping forces between comparable bolts versus studs.
Considering your posted 5/16" bolt specification of 2300lbs, why shouldn't a fella hook not one, but TWO engines on ONE bolt (as I suspect 2 engines would not weigh a total of 2300lbs)...? Why not, because, as you point out, there are OTHER FACTORS involved when lifting an engine that the "bolt shear strength chart" doesn't consider. Such as side loads, loading to the bolt head, jerking loads, and as mentioned earlier, there may likely be corrosion to the bolt or the threads in which the bolt is in, which would lessen its clamping / holding capacity as well; none of which are considered on the chart.
This discussion reminds me of the advertised strength of chains....
Anyone ever break a chain while trying to move objects that weighed much less than what the chain was rated for? Such a situation brings us back to the OTHER FACTORS INVOLVED that are not considered when only the rating of the chain is considered.
BarnieTrk
