63 uni short bed start
Anthony's Son
Re: 63 uni short bed start
Post by Anthony's Son »
I would really like to put dual Quads on it but, if I were to spend alot of money on intake and carbs, it would get this... http://www.summitracing.com/parts/SUM-CSUM1906/ ... Haha.. I am hoping to get the wheels off tomorrow, and try to get started on the brakes.. then if i have enough time before it rains... possibly fuel tank.. thanks for the links by the way guys :thumright:
Zak
1963 uni short bed
sub framed tubbed
351W carbed and C6 are the plans now..
1963 Short bed Flareside
302 3 speed
Daily Driver
jkimbrel65
Post by jkimbrel65 »
http://www.carlsfordparts.com/main.html
Get em here a bit cheaper
Mike
I tried being normal once...
Anthony
Post by Anthony »
Thanks Mike! So I was thinking that the 289/302/351w took the same intakes? But you have to buy the adapter plate to get the triple deuce to work on the 351w.. :hm:
Forgot I was on dads name again... Thanks Mike - From Zak
Anthony's Son
rear brakes checked out really good
front?? no so good at all.. have to replace rotors calipers, no lines ran to them..
Also seen that i will have to make my own shock mounts (I think)
Zak
1963 uni short bed
sub framed tubbed
302 3 speed
Daily Driver
Anthony's Son
Zak
1963 uni short bed
sub framed tubbed
302 3 speed
Daily Driver
BigWindowFord
Post by BigWindowFord »
The 351w is a tall deck version of the 260/289/302. That means that the factory added material to the block to accommodate a longer stroke. Think of the V in V8. If you lengthen the sides of the "V" the space in between widens, hence the need for a wider manifold on the 351w.
Below the manifold line everything is about the same for the 260/289/302/351 and the valve covers are the same also.
Regarding the tripower unit keep in mind that a lot of these parts are available used and aren't hi-tech to begin with.
For $2700 you could also get a 4 weber setup a-la Cobra.
Anthony's Son
Thanks Big Window Ford, I was talking to dad "Anthony" today about just going carburated, because the high pressure fuel line might be a little more expensive.. it is looking like cam the motor out and go with intake and carburetor.. I was told like a 480/280 cam is about the biggest I can go with all stock and no converter..
Zak
1963 uni short bed
sub framed tubbed
302 3 speed
Daily Driver
