I made a frame by bolting together some aluminum square channel I had, and added four tongue jacks from harbour freight. You coud use wood instead if you find good clear 4x4s
I needed to do it in steps with cement blocks, and remove the rear tires, however it was the complete unibody not just the cab.
it has been posted here, to put a piece of plywood on the rear frame and roll the cab back on to it, It works great I tried it on my sons stepside cab
