My soon to be 64 (or 66)
Anthony
Post by Anthony »
It doesn't matter how you fix her up, as long as you like it and enjoy it.... Any and all Slicks are welcome here, whether they are "cool" or just the old "farm" truck... :lol: and Welcome from West Virginia!!!
dbrady
Post by dbrady »
Here it is on pickup day (pickup the pickup). Love the F150 (new) bringing home the F100 (old).
First order of business is to get it running. Needs a carb rebuild and probably a water pump (we'll just have to see). Work and finances are on the 67 Mustang project as the motor is now coming together. The F100 is project B. But I predict the F100 will be on the road before the 67 Mustang.
I need to get a replacement title. Need help finding the correct VIN. The doors are from a 66 F100 so that VIN is no good. Anyone know of a second location to find the VIN.
Many thanks!
Darren
2010 F150
1967 Mustang Coupe
1966 F100
Gatkpartz6179
Post by Gatkpartz6179 »
welcome...plenty of parts available to get it into a workin daily driver truck..I have everything to get your s.colum correct with signals,etc. and should you want the correct grill,etc for when you find out the actual year I got that oo, plus I am sure there will be a few folks wantin your take offs..Theres no need to fuss out or dammage anything on your truck,somebody's already figured out the fix and its posted here...somewhere...
Yep, this is Pete!
Gatkpartz6179
vin
stamped into frame rail....
Yep, this is Pete!
HiBoy63
Ireland
Post by HiBoy63 »
Look on the passanger side frame rail top. In the area of the front of the engine. Probably ahead of the shock tower. Under the cab on top of the passanger side frame rail. You may need a wire brush and sandpaper and some sort of cleaner to find it. Good luck.
1963 F250 4x4x292
1965 F100 4x4x352
1998 F150 4x4x4.6
2001 Sport Track 4x4x4.0
Heritage country Flag
Hookedtrout
Post by Hookedtrout »
Sounds like you and I have about the same projects going. I've got a 68 GT/CS Mustang I've had since the 80's that needs a restoration, it runs great but the paint is faded and the interior needs redone. And I have the 62 Unibody Shortbox I'm restoring. We certainly have a couple of the best old Fords made. Good luck and keeps us in pictures.
Cory
1962 F100 SWB Unibody, 223
1931 Ford 5 window coupe
dbrady
Post by dbrady »
Thanks for the 411 on the alternate VIN location.
Regarding the 66 parts (doors, fenders, hood, grill, etc.) - the metal is in great shape. I'll probably just keep on the truck and remove the I-Beam badge. I like the look of the lights within the grill for the 64 rather than above in the 66 but I suspect the hassle of swapping out is probably not worth it.
Darren
2010 F150
1967 Mustang Coupe
1966 F100
dbrady
Post by dbrady »
Its a 67 mustang coupe - needs complete restoration. Pic is of day we brought it home.
This photo is around October 2010. First thing prior owner did was buy rims and tires. My son likes them so guess they will stay.
It came with a 289 (locked up) and guy tossed in a 302 block, heads, etc. (which is why the trunk is so low). Floor pans already replaced and some of the engine compartment panels replaced as well as, a new radiator support.
Block is back from shop and being assembled. Trying to get the cowl removed so it can be swapped out and we can finished the engine well. Once I get the engine well painted, motor in and cowl replaced, will shift focus to the F100.[/img]
Darren
2010 F150
1967 Mustang Coupe
1966 F100
Hookedtrout
Looks like a great start, I like the wheels as well. I have the original styled steel wheels with trim rings and caps for my CS but I rarely ever run them on the car, just save them. Here's my pair, both running, just ran the Mustang up and had the front end aligned this morning, I had SSB Disk Brakes installed and it needed aligned so that is done now.
Cory
dbrady
Post by dbrady »
Very cool pic - thanks for sharing.
I look forward to the day I can snap of pic of both the 67 Mustang and 64 F100 together as drivable.
Darren
2010 F150
1967 Mustang Coupe
1966 F100
dbrady
Post by dbrady »
Got the 390 to turn over and start. It's not good. Possibly a pushrod going bad. I only took this specific truck on with the notation the motor was in running condition. Given the time and money to rework the motor combined with the truck being a hybrid of 64 and 66 components, have decided I'd rather sink money into the mustang restoration. Am going to sell of this truck. Dropped a posting on Craigslist for $1,250 and will take that money and find another slick.
Yeah I know a slick in hand is better than trying to find a slick but I was hoping to get a cheap driver first and than circle back and fixup later.
I think if the motor was anything other than a 390, I might feel differently but at this point am going to try and cut my losses.
The cab does have both of the boxes and trim rings for the door, so if you have been looking, have no problem parting out to my fellow slick posters.
Darren
2010 F150
1967 Mustang Coupe
1966 F100
Paul Merrell
Post by Paul Merrell »
I have a 352 in a 65 it runs but needs to be checked out. I could check it this weekend for you. Will sale engine for $50.00
slickmainer
Post by slickmainer »
option b sounds like a good one to me. id upgrade the brakes though
--Gregg--
you can't get there from here
dbrady
Post by dbrady »
Yes - am definately looking into Paul's most gracious offer and plan B.
Darren
2010 F150
1967 Mustang Coupe
1966 F100
Haus
Post by Haus »
Used to own a red headed step child (64). Looks like you have a good truck to start with. I have 1 truck I went off the deep end with and because it was such a task I bought a second one just to enjoy and not really pull apart :D
Either path you take will be just fine. Its your truck and your money.
PS: The 64 and 66 grills are my favorite. Either one you decide to use will look awesome. You already know the 66 grill will start any conversation with a truck guy with, "no its actually a 64" LOL. Just like anytime I tell someone I have a 351 cleveland in my truck.
All my tools are hammers except screwdrivers, those are chisels.
1966 F-100 2WD
351 Cleveland **no its not a 351M**
C4 trans
3.50 rear end
Gatkpartz6179
parts
remember too that if you want to put all the coorect sheet metal back on
i have it and we can prolly swap some..suggest you pull the valve covers[352,not 390] off your motor,there no such thing as a pushrod going bad,its either bent or not,you either have a sticking lifter or rocker issue all easy stuff...
Yep, this is Pete!
dbrady
Post by dbrady »
Deleted the craigslist posting to sell. Thanks to those with the pm's and suggestions. Look forward to moving forward with this project.
Darren
2010 F150
1967 Mustang Coupe
1966 F100
