One Wire Alternator
64Ranger
Post by 64Ranger »
Thanks for the help Banjo... that makes good sense.
Doug
Riverside, CA
sully5
Post by sully5 »
Word of warning about 1-wire alternators:
1. They don't start charging until they reach a certain RPM (the level set to "excite" the regulator.
2. If your alternator goes out, you generally cannot go down to Advance or O'Reilly's to get a new one in a pinch unless you alread have the traditional wiring in place taped up for such an eventuality.
I have run them, you just need to be aware.
qwertyd10n
Post by qwertyd10n »
Hey guys,
This is the direction I'm going... here's my new PA Performance alternator that was delivered today:
The model number is 1614E and is a 95A 3G unit with an internal regulator. I will be using PA's 3G Conversion Plug kit (#462802B) to eliminate the stock wiring to the external regulator. I also paid a little extra to have the housing powder coated flat black to match my other accessories better. I live the way it looks!
Cheers,
Dion
Leeroy
Post by Leeroy »
Or you can convert it back to a 3 wire which I did, sounds stupid but that way the dash light still works and you know if its charging or not.
qwertyd10nYou'll love that upgrade, I've one it to both my classics and love it.
64shortbed
Post by 64shortbed »
I found this thread very helpful. Thanks guys.
-don
'64 F100 262-I6
Jonas
Post by Jonas »
If you go with the one wire altenator does it eliminate the voltage regulator too?
I am about to do a complete re-wire. It could simplifie things
1997 F250HD 460 4X4
2004 RoadKing
1984 FLHS
1978FXE
yes
the regulator is inside the Alt.
charliemccraney
Post by charliemccraney »
If you want idiot light functionality with a 1-wire, Ron Francis offer a device just for that.
I've been using a 1 wire for probably 9 years now, trouble free. The rpm required to excite it is less than my idle rpm so that is not a problem. They aren't that uncommon. Some parts stores do stock them along with other aftermarket products. If yours does quit, you can very likely have one within a day by ground shipping, and you'd be surprised how far you can get on just a charged battery, running only the ignition, if you had to.
Given my personal experience, I will not hesitate to use one again in the future. Plus, the stock regulator location is great for mounting ignition boxes without drilling additional holes.
William-in-St George
Alternator Conversion
I know some here resist Cheeeveee parts on our slicks. But, if you want an quick, cheap, easy, available on sunday conversion read the tech article over on FTE. This deal uses a 12SI alternator and the idiot light works. I have used this setup for years without any issues whatsoever. My new project will use the Ford 3G just because I like Ford stuff on my old bug. IMHO!
William-in-St. George
Leeroy
Post by Leeroy »
Another thing that I remember about this conversion, try to get one with the v belt already installed rather than swapping one on.
The first one I used on the mustang was actually a serpentine pulley that I had rattled off and installed a v belt. It worked ok, but it needed a smallish shim to have it lined up correctly. It looked ok without the shim but made some belt noise and kept wearing belts quickly until it was shimmed correctly. The one I bought for the slick that already had a v belt was perfect.
It's not a big deal, but it can be annoying if you dont have a rattle gun to get the bolt off. And DON'T try and stick anything in the case to jam the internal fan if you take the bolt off. Yes.... I learnt the hard way.
I used this seller, eagleautoelec on ebay.
http://www.ebay.com/itm/360409779130?ss ... 303wt_1180
