Page 2 of 2
Re: Valve cover racing
Posted: February 23, 2012, 9:46 pm
by ezernut9mm
Toyz wrote:ezernut9mm wrote:sold the only v8 in the stable. fe's are famous for leaking anyways. if took them off to race i'd have to buy stock in exxon/mobile. old sixxes are way better anyways.
You know I've got to go with the Windsors! Full roller is the only way to travel
i owned a windsor once. i never really got a good look at it though. too much stuff on top to really see anything.
Posted: May 18, 2012, 4:30 pm
by dadstruck
I am sure I can scare up an old valve cover.
What are the rules?
Can it be any valve cover?
Posted: May 18, 2012, 9:35 pm
by Kid
cant break the track, cant hurt anybody, should be Ford
Posted: July 15, 2012, 8:00 pm
by slixtyfive
So I think I saw on another post that the only real rule is that there are no rules??
But I'm assuming there are some limitiations on physical dimensions for them to fit the track?? What might those be??
Thanks,
Posted: July 15, 2012, 8:17 pm
by Kid
I think each lane is 11.5 in wide so it needs to be able to fit and run on it
Posted: August 4, 2012, 10:03 pm
by kstones63
Kid wrote:I think each lane is 11.5 in wide so it needs to be able to fit and run on it
Holy crap, Are you sure that is all the wider that the track is???????
I just finished building mine and the valve cover is 11 3/8" wide.
What do I do Now??????
I might be able to modify it and get it down to 10" but that will be the minimum.
What kind of weight should these be? I need to know if I should add weight to it to make it faster.
Kevin
Posted: August 5, 2012, 9:41 am
by Uncle Skip
If you google it, there are actually printed rules.
The one I noticed most was a "10 pound" maximum.
Why build a racer that you can only race in one place. Build on you can take to other events and race legally.
Posted: August 5, 2012, 10:56 am
by kstones63
I guess mine won't be able to be raced any other place. It already weighs 15 pounds and that is only with the valve cover, wheels and mounting plates. I guess the valve cover is just too heavy being cast aluminum.
Now I am just worried about the width of the track. I can cut off a tab on one side and get it down to just over 10" wide.
Kevin
Posted: August 5, 2012, 11:20 am
by Kid
I am not sure what the width of the other track is we used but I was trying to conserve a little and get 2 sections from 1 sheet of plywood and I still have $500 in it. I do remember one of the " Official Rules " is the 10lb limit but I am not sure on the rest of them. I was suprised..............KId
Posted: August 5, 2012, 1:35 pm
by Uncle Skip
