I've been having "running" issues with the 292. Thinking that part of the problem is the new carburetor, specifically the power valve. I read that if you screw the idle mixture screws all of the way in and it doesn't change the idle of the engine, then the power valve is bad. The truck starts and runs great until it gets warmed up...then it misses (some).
I just paid $200 to a friend for the engine and tranny out of a '92 F-150. He bought the '92 for parts for his truck and didn't need the engine or tranny. It is a 302 EFI with the automatic overdrive. He and I will remove the engine, transmission, and all of the related electronic components. The engine has over 200k on it, so the plan is to go ahead and tear it down and rebuild it. It will be a few weeks before we can get together and remove the engine/tranny.
I will do my best to photo-document the process. I am planning to do the rebuild myself, except for the machine work. Also, I want to keep the engine stock for reliability and fuel economy. Right now the 292 is only getting about 12ish mpg....I think that the 302 should get at least 15-18 or maybe more even with the automatic behind it.
So....
Stay tuned.....
04sd
Post by 04sd »
That's what I have for my truck, a 92 5.0 with the AOD. Both of mine are about 25K on rebuilds so we will see after I get the truck back together. This set up gives you speed density efi and an overdrive that doesn't need a computer or speed sensor. My initial plan had been a 2000 Explorer 5.0 with the 4R70W trans but I just didn't want to deal with the added electronics. With the AOD you can even take 302 back to a carb and eliminate the computer all together. I'll be watching to see how your build goes.
Bill, Thanks for the feed-back! From your information, I've made a good choice for my truck. I discovered this afternoon that the problem with my 292 was the vaccum advance on the distributor. It was bad, thus the carburetor was sucking air into the vacuum port. Going to pick up a new vacuum unit after dinner this evening. We will see what that does for the old 292. It did run better after I plugged the vacuum port on the side of the carb.
04sd
Post by 04sd »
I was really torn with what to put in mine but I had to have automatic and a transfer case. I thought about keeping the factory 352 with a C6, 351M/400 with a C6, 460 with a C6, 351W with a C6, and various 5.0/5.8 EFI engines with the overdrive autos. In the end I went the way I did because I thought it would make a nice driver that gets OK gas milage and, setting up the truck with a Windsor motor gives me the most low cost options down the road for a pushrod V8.
Not much to report...the new vacuum advance unit fixed all of the running issues that I was having. Removing the old carburetor with the velocity governor and installing a new carb probably caused the diaphram in the advance to fail. I don't know for sure...
Cleaned it up and went to 2 cruise-in's this past week-end, one on Friday night and one on Saturday. There were 2 other slicks present at the Saturday cruise-in. I didn't get any pics though.
Waiting to get the 302 and automatic overdrive transmission from my friend...he lives about an hour away. But right now we've (my wife and I) been "entertaining" grandkids...Whew! I am about worn out! We had our 10 year old grandson last week and we have our 4 year old granddaughter this week. First time for her to stay...we got a pic made for posterity's sake.
Stay tuned...more stuff to do....more stuff to come!
....and I had posted earlier on this thread (about 2 years ago) about a '66 Ford Galaxie that was sitting a few miles from my home. My dad bought it this afternoon. That will be our next project. 390 with auto overdrive. The interior is orginial and almost perfect. Exterior is only surface rust and faded paint, no dents or rust holes. It needs tires, battery, fresh fluids, etc. etc. Excitement abounds!
'nuff said!
ratrapp
Post by ratrapp »
I had a 65 2dr when I was a teenager.289 3 on the tree.one of only 2 vehicles that I regret getting rid of.the other was my 63 f100 shortbed.
04sd
Post by 04sd »
That 66 looks to be in really good shape.
04sd wrote:That 66 looks to be in really good shape.
It is! The interior is in amazing condition...untouched. The exterior is straight as an arrow, it just needs fresh paint. Getting some tires on it in the morning and then pulling it to my house. Hope to get it running within the week.
Well after 2 weeks we have the Galaxie running and driving. We have found that the car has only 30542 actual miles. The original owners manual was in the glove-box with the lady's name typed in the front cover and the date that she bought the car new from the local dealership. Through a google search we were able to verify some information that leads us to know that the car was only driven to the grocery store and church on Sundays....It's true! The car had been left sitting in the 3rd owners yard for the last 15 years. He had started it up occasionally which probably saved the engine from locking up. It drives and rides like "butter"...that's how smooth it is. Here's some pics that show that the car experienced very little 'usage.'
Original spare tire...it's never been out of the trunk...
Under the dash...note the condition of the black rubber piece that holds the carpet in place.
The headliner is in perfect condition...
Original carpet (needs cleaning) and the drivers side of the seat is starting to tear...the fabric is dryrotted but original...
I don't think anyone has sat in the backseat...dad and I pulled the bottom out and it was perfectly clean under it...no change found and no body parts either lol...
Stay tuned....driving the truck and enjoying working on the Galaxie...We're going to start sanding the perfect body down in prep for a repaint in the original "Tahoe Turquoise" color.
Continuing to drive and enjoy the truck. We have been to several cruise-ins this season. Also helping dad with his '66 Galaxie. It runs, drives and handles like a brand new car...which it is! This week we started sanding it down in preparation for a new paint job. We will reshoot it in the original "Tahoe Turquoise" color. It will be an easy "scuff" and "shoot"...we hope.... One thing that I noticed, and mentioned to dad, was that the car did not have a single door ding in it...
This car is going to be beautiful when it is finished. Dad paid $1800 for it and after a paintjob and some mechanical freshening up it should be valued in the $10k to $12k range.
Stay tuned....we'll be back!
(I've got some sanding to go do.....)
Well....a little more sanding completed this afternoon. Here's a pic of the '66 Galaxie the day we were bringing it home...
And here's where we finished up this afternoon...
We still have the top and all of the driver's side to sand down...
And here's a pic of my truck and dad's car out in the yard...we had a downpour going on!
More to come...stay tuned!
...and the date on the pic in the previous post is wrong. Dad's camera date is messed up....lol....
....still sanding......
....and sanding.......
.....and sanding......
Hoping to get it entirely in primer by the first of next week.
I'm working on dad's Galaxie this morning. He had some rust out at the bottom lip of the trunk opening that needed to be addressed. Here's the section of bad metal that I had cut out...
And the two pieces of bad metal...
I made a patch piece from some metal that I already had...did it the old fashioned way and cut and shaped my own patch piece from scratch. It was a lot of work, but worth it.
Here's the patch welded partially in...
I came in for lunch and am planning to finish it this afternoon. I will post pics of the finished mess...lol...
Stay tuned...
Finished up the trunk area...turned out fairly well. Now to finish sanding the driver's side doors and the drivers quarter panel...
Getting close to being ready for paint!
MOST of the sanding is finished. We still need to sand the cowl and a few other minor places. AND I still need to finish the driver's quarter panel. The car was covered in dust so I pulled it out of the garage to wash it off....took some pics:
I'm going to try to finish working on the quarter panel tomorrow and start on the cowl...hoping to spray some Acrylic Enamel the first of next week...
Stay tuned....
Drove my truck an hour and a half yesterday to a friends house to 'harvest' a 302 with auto for my '64. We ended up not removing the engine from the donor truck. It was a 4 wheel drive and it was going to be more work than it was worth in my opinion. But my '64 drove well up the interstate, cruised happily at 70 all of the way. The 292 is running well...so if it's not broken...why "fix" it?
On another note...dad and I are still working on the '66 Galaxie. It takes a lot of sanding to get a vehicle ready for paint...even one that is already straight. We have the car completely sprayed in one coat of Epoxy primer. Today I am going to spray two coats of surfacer/high build primer on it. We will give it a final scuff with some 320 after the primer shrinks and I think that we will be ready to shoot some paint on it. Dad has been busy cleaning and shining up all of the chrome trim. Pics to follow...
Stay tuned....
This afternoon's accomplishment...
2 coats of surfacer/high build primer. I will let that "cure" for a day or two and then sand with 320.
The car is sanded and prepped! If the stars align tomorrow, I will shoot some color on this thing...
