blasting media
Posted: May 8, 2009, 7:20 am
by dotcentral
I have some parts that I need to blast. I have access to a blasting cabinet but need to have my own media. I want to blast some small parts, and the sheetmetal piece that fits between the top of the grille and the front of the hood.
What is the cheapest and safest stuff to use, that won't warp? Or will the varius stamped curves and rolled edges keep the one sheetmetal piece from warping?
Posted: May 8, 2009, 8:03 am
by BarnieTrk
Here are a few brief discriptions of the +/-'s of the more popular media types:
http://www.kramerindustriesonline.com/f ... -guide.htm
Here is a popular supplier of the different blasting medias readily available:
http://www.eastwoodco.com/jump.jsp?item ... e=CATEGORY
Keep us posted on your progress!
Good Luck!
BarnieTrk :cheers:
Posted: May 8, 2009, 9:51 am
by Lowell
I have used regular masonry sand after sifting it through a screen. Its probably the cheepest way to go. Just be sure it is dry or it will clog the nozzle .
Posted: May 8, 2009, 9:57 am
by dotcentral
Thanks for the links, but not sure which ones are good for rust removal. Of course there is the cheap, and potentially harmful (to me and the parts) silica sand.
This would be outdoor blasting, no cabinet, so will be hard to recover.
Walnut or something else?
http://www.northerntool.com/webapp/wcs/ ... tial&N=109
Posted: May 8, 2009, 10:14 am
by 61 Merc
I all depends on the condition of the metal and what you want from the outcome. If you are just removing paint or surface rust, use either glass beads or soda, if you need to remove rust, then go with the sand. If it is an outdoor blaster, I would go with soda, it allows the paint to strip off and should not mar or pit the metal which will happen with sand.
Some soda blasters also have water induced into the nozzle to reduce the dust.
Dean
Posted: May 8, 2009, 10:24 am
by dotcentral
I will be using a blaster without water, just compressed air.
Pretty heavy rust on the back side, don't think it was ever painted. the front is more like surface rust from where the paint and primer wore away.
I may be some sand for the back side, something else for the front side.
Posted: May 8, 2009, 11:03 am
by 61 Merc
Then go with some sand for the back and use soda for the rest. Soda is biodegradable and a cost effective way to go.
Dean
Posted: May 8, 2009, 11:22 am
by BarnieTrk
I read - somewhere - that when using soda for a blasting media that you should make sure you use a 'neutralizer' before priming, if not, it will effect the paint later....... ?
I also read that if you're doing the soda blasting outside near any plants / grass, that the dust should be rinsed off the plants because they don't like the dust AT ALL......
This is NOT first-hand info, just what I've heard/read.
Good Luck!
BarnieTrk :cheers:
Posted: May 8, 2009, 6:41 pm
by 1961 slickwilly
i've used corn meal like you buy at walmart or any grocery storeit don't get hot like sand does whicch cause the warping it cost more but its takes off paint and primer and rust but if your refering to the part you got from me i'd use some sand on the back and corn meal on the front
Posted: May 8, 2009, 9:31 pm
by dotcentral
I forget exactly what media I bought, but it was a little big and tended to clog easy. Anyhow once I got it running through the sandbalster I rrealized the peice was too rusted, I started blowing holes in it. :(
That's life, or I should say, rust for ya. I didn't pay much for the piece so I'm not out a lot.
Posted: May 9, 2009, 8:12 am
by 64 f100
Corn meal? Would seem like a very expensive blasting media indeed. Besides buying all those little 2 pound bags at the grocery store. I have set up an outside blasting cage by putting down a tarp and reusing the sand . I have at p[resent a small blaster and it works but is slow, of course. My biggest problem is the moisture from the small compressor clogging the sand in the blast pot. Working on getting a bigger compressor set up for this moisture problem. I also have a blast cabinet, but have not set it up yet. It came from a plant with plenty of air, and has a large nozzle and uses lots of air. Don't have any media for it other than blasting sand, and did pick up some of the black blasting media. Don't yet know which to use. Mostly for use with small iitems, land heavy rust. Got a hopper at the bottom so I can dump the media and replace it with finer stuff if needed.
Posted: May 9, 2009, 12:45 pm
by 1961 slickwilly
yea the corn mill is high but you can buy it at sam's in bulk like 50lbs bags for cheaper but it works leves a nice smooth finish and don't get hot and warp everything
Posted: May 10, 2009, 10:49 pm
by Tech
150 / 180 grit garnet
80 grit leaves a rough surface
220 grit is fairly slow to remove thick paint and rust
corn starch is designed to be recycled. The new fractures are what cuts.
Aluminum oxide cuts ok but it has been screened to a significantly tighter standard and costs more.
Warping shouldn't be an issue on small parts.
Soda is not my thing
Tech
Sandblaster question
Posted: May 11, 2009, 12:47 am
by Sixty2Unibody
If I use corn meal, what do I need to do to my sandblaster? Any modifications to go from sand to corn meal? I'm stripping the paint on my Uni and I think this may be the way to go.
Thanks!
Posted: May 11, 2009, 4:23 am
by jakdad
These are the folks I deal with.
http://www.barrelblaster.com/
Posted: May 11, 2009, 5:23 am
by 62galxe
black beauty works pretty good. doesnt clog like sand.
http://www.reedmin.com/black-beauty/bla ... sives.aspx
Posted: May 11, 2009, 6:14 am
by Shawn F.
Black Beauty works great. A place in SC (Rock Hill I beleive Tim) sells blasting media. Do NOT use soda to blast any parts you plan to prime and paint. You will be looking at a huge mistake. Paint suppliers and reps will even tell you that they will not cover any mistakes if painted over a vehicle that has been soda blasted. The shop I worked at in SC did this to a 69 Camaro I beleive. They put it in primer and paint after I left and I heard it peeled, blistered and had lots of problems.
Posted: May 11, 2009, 8:48 am
by Sixty2Unibody
Thanks'
for the info everyone. I live in Eugene, Oregon so I need to find something closer than Texas or SC. I haven't heard that about soda blasting as long as you wash everything down with 10% vinegar mixed with 90% water. Looks like more research time and I read somewhere that the soda blasting leaves a residue that prevents rusting for a short time which is the reason for the vinegar/water washdown.
Posted: May 11, 2009, 7:13 pm
by 62galxe
pretty much any media supplier will carry black beauty. commercial suppliers usally have the best prices and selection.
