AC a coming
- stronger66ratfink
AC a coming
Well finally getting to the top of that big "bridge" for the down hill roll!
Max and I are going over to the local Vintage Air Dealer which is just a few miles from me on Friday to look at the set ups they have, already spoke to them and sounds real good, just need to pick out the controls and hoses at least for the set up that I'm going to put in my truck, Summers are just to long and to damn hot and until they move SlickStock to April or late October the vent windows won't cut it any more and I want to drive the truck more, the hole system sounds like the set up is going to run around a grand, which I don't think is to bad? but the serpentine set up that I'm also getting from March Performance is going to make it just a little harder. Max has got it easy, he just has to stick his in, I've got to take parts out first. pictures at 11
Keep us posted. I think AC is a goal for all of us (at least in the South)
- dotcentral
Air Conditioning was a big milestone for me also. I got mine installed this winter. It sure was nice driving to the truck show in Alabama with plenty of cool. My 86 year old mom rode with me as far as Mississippi and without A/C she would have never made it. I was wondering how good it was going to work in my truck with all the extra heat the cab soaks up sitting on top of the engine. To my surprise it worked very well. With day time temps in the mid 90's I never moved the blower switch off of low speed. I kept the thermostat knob at about 3/4 cool.
Michelle
I'm going to go over to Mike's house and watch him struggle with his installation before doing mine. I think that would be the smart thing to do.
It's the only way I can gain any ground towards his trophy collection.
- Hoofbeat Racer
- stronger66ratfink
I just got mine working last week. I've got the classic auto air set up. I've had everything bolted on for a while now, but I finally took it in and had the lines made up and the system charged.
It was blowing hot air at anything but an idle. Turns out I had the valve for the heater core on the wrong heater hose. The instructions call of it to be on the return side. I bypassed the heater core temporarily and now I'm cursing cool
I've just got to sort out the whole heater control valve thing before winter gets here.
I know what you mean about mileage. I'm pulling down around 10 mpg now and this is with a 302. I've hooked the vacuum advance back up in an effort to get my millage up. I would expect at least to 12 to 14 mpg even with my cam and 3.55 gears. I've got a year to dial it all in before the Slick Stock convoy.
SBC is a defunct phone company, not an engine option.
Installed a vintage air unit inside my 66 f100,behind the glove box. I used the stock Ford brackets on the motor with a generic aftermarket compressor and condensor. Made up the hoses with lines and fittings from Vintage air,mounted the controls in dash to right of column.Hardest part was getting the fitting on the hose.Works very nice, would do it again.
You guys have all the luck with the vintage air units that fit right up. I wish it could be that easy for my truck. The vintage air will not fit my truck because of the tall external cab mount brace that is located on the fire wall of the cab. It is right in the way of where the A/C lines would locate. Also because of the dog house it will not fit properly inside. Also had to mount the condenser in another location because of the shutters in front of the radiator. When the shutters close with the A/C on it would build up to much head pressure. I mounted the condenser on the side of the frame rail. It is a self contained unit with its own fan and is wired into the compressor so it only comes on when the compressor is running. The compressor was another obstacle. No one but no one makes a mounting bracket for the compressor for a Cummins engine that has not been made for nearly 40 years. It would normally mount just above the accessory drive, but my truck has power steering and the P/S pump is mounted in that location. So there again I had to fabricate some brackets to mount the compressor. My evaporator unit is a Red Dot unit especially made for big trucks that produce a lot more cab heat than does a regular pick up. I mounted it between the seats on the rear of the cab where the fuel tank would normally be on a pick up. Again I mounted it with fabbed brackets and drilled no extra holes in the rear of my cab for mounting. The dryer is mounted behind the passenger seat with the A/C hoses going through the floor under the passenger seat.
The belt is adjusted via the power steering pump as the same belts drive both
The seat is yet to installed in this photo
The condinser was fairly straight forward in its mounting on the frame rail. I did use a piece of square tubing to space it out from the frame even more than it already was.
Michelle
- dotcentral
I have an older underdash unit I want to use, not sure of the brand. Once I start on the cab interior I'll need to mock it up and figure out where to pass the hoses into the cab.
Those that have added a/c, did you use a bulkhead to bring your lines into the cab, or just use a grommet around the lines?
- Uncle Skip
Hey BlueGhost,BlueGhost wrote:I just got mine working last week. I've got the classic auto air set up. I've had everything bolted on for a while now, but I finally took it in and had the lines made up and the system charged.
How do you like that Classic Air set up? Is it the one that is supposed to be designed for slicks? Does it bolt in where the existing heater is? Have any pics of it?
Thanks for any info. I've been looking at that unit but haven't talked to anybody who has one.
Looks like you're covered Mike. I felt Roger gave me a pretty darn good deal and ended up getting the Gen II Mini unit. I left with everything except the condenser (didn't know my radiator dimensions), drier or hoses (need to mock up everything and get all of the fittings with the hoses).
Just with a trial fit, looks very nice and since I've been welding up all of the previous holes in my firewall, I can re-route the main lines wherever I'll need through the firewall.
Turns out my Father had remodeled Roger's house not too long ago.
