Finally got moving on the 65
Posted: March 22, 2010, 10:27 pm
by Michelle
It has been a slow start on the 65, but I got a dolly made for the bed and I already have one for the cab. The bed is removed and started body work today. I will be including some pictures as we make progress. Think I will be ready for Slick Stock? Anyone taking bets?
Posted: March 23, 2010, 5:08 am
by Anthony
I think Slickstock is a go with your determination Michelle. Can't wait for the pics to start rolling in.....
Posted: March 23, 2010, 9:01 am
by semotrucker
Good luck Michelle...will be waiting for the pics also. Are you going full restoration or resto mod?
Cam
Posted: March 23, 2010, 9:17 am
by Michelle
I will go all the way with it. I am removing the bed and the cab so I can sand blast the frame and paint it. I had considered leaving the cab on and painting it on the truck, but decided against it because the front cab mounts need some attention. The engine runs great, but leaks at every gasket. I will remove it and replace all the gaskets and freeze plugs and probably the rear seal at the same time. Wiring in the truck is solid and everything works, so it should be no problem. The truck is a low mile truck with tight steering and good mechanicals, so I shouldn't have to do muck there. With a little luck and good weather I should have it to the point that it will be presentable enough to haul up to Iowa on the trailer of my big Slick.
Posted: March 23, 2010, 10:19 am
by slickmainer
hope you take lots of photos so i can learn the steps. Decided on a color scheme?
Posted: March 23, 2010, 2:04 pm
by Breezeman
You Go Girl.
Im at about the same stage you are. Mine is down to frame for sanding and painting. Getting new floorpans put in and some other minor sheet metal work done. Can't wait to see some FRESH paint being sprayed.
Take Care and Good luck on yours,
Larry
Posted: March 23, 2010, 8:58 pm
by Max
Hi Michelle, who do you use for chroming? Someone in your town?
Posted: March 23, 2010, 9:00 pm
by Michelle
There is a place in Austin that will straighted and chrome them. The bumper on my big truck was bent when I got it and they straightened it.
Posted: March 23, 2010, 9:02 pm
by Uncle Skip
Never.
I mean NEVER bet against a woman.
On anything. They cheat.........
Nice job Michelle.
I'm getting ready to shoot the bedliner on my bed too. I built a small support with casters for it too.
I'll let you all know how it goes, but the product from Al's Bedliner looks really good.
U@ss
Posted: March 23, 2010, 9:15 pm
by ezernut9mm
another truck i can't wait to see at ss.
Posted: March 23, 2010, 9:16 pm
I am betting you are more done than me when SS arrives.
Posted: March 24, 2010, 9:26 am
by BarnieTrk
Posted: March 24, 2010, 10:09 am
by Michelle
You could get an aftermarker bumper or a Ford accessory bumper. I think the aftermarker bumpers were cheaper, and that is probably why you don't see more of them. Here is a picture of the bumper from the other side, you will notice that is has the same contours as the front bumper. The C4 (64) part number would not be out of the question for a truck built in 65. The bumper probably came right out of the parts department of the selling dealer.
Posted: March 24, 2010, 10:26 am
by BarnieTrk
Michelle,
Very interesting...thanks for the enlightenment!
Do you know whether or not the Slick FoMoCo 'accessory' rear bumpers were availalble ONLY as a chromed piece or were they also available as a painted bumper?
BarnieTrk
Posted: March 24, 2010, 10:34 am
by Michelle
BarnieTrk wrote:Michelle,
BarnieTrk
I am not totally sure about that question. I can only say that during the day I only saw the chromed ones. My dad worked at a Ford dealer and there was a chromed rear truck bumper on display in the parts department as an accessory item.
Posted: March 24, 2010, 5:35 pm
by cdherman
You could get them painted, or at least I have personally seen a painted one -- I saw it driving around town once. Could of course been someone that painted over a chrome bumper, but judgeing from the rust and the general condition of the rest of the truck, I think not.
Michelle -- what engine is in there? Sixes all leak like sieves. I did a frame up on mine too, but did not mess with the engine, as it was running fine. I regretted that later, as replacing all those seals sure would have been easier with no truck around the engine to deal with....
Posted: March 24, 2010, 7:01 pm
by Michelle
Got a little more done today. Did some blocking on the tailgate and got the front clip removed. I have never seen a truck with so many bolts to hold the front sheetmetal on. It was a major effort to the everything off. My 56 did not have that many holding things on, and my big Slick didn't have near as many. Of course the big Slick was designed where you could easily remove the front sheetmetal easily so you could gain quick access to the engine.
