Page 1 of 2
Is this proper for a front bumper?
Posted: April 25, 2010, 5:58 pm
by kstones63
This doesn't appear to be correct to me. This bumper seems like it should have a slight curvature to match the gravel guard. This is a bumper that I purchased from LMC 4 1/2 years ago. I am now finally ready to put it on and it doesn't look right to me.
It appears to be too straight to me. I can modify the brackets some to bring up the outside corners, but I don't think that I can bend it to make it have the proper curve.
Do I need to call LMC and complain?
Do I need to grind the proper curve into this new bumper, push the mounts back and then have it rechromed?
Any ideas?????
Kevin
Posted: April 25, 2010, 6:05 pm
by pugsly
my 65 looked the same way.... so i cut off the frame horns and made a front roll pan... lol i really didnt do it for the poor fitment. i was told the bumper was from a 67 - 72 but i dont know how accurate that was.
Pugsly
Posted: April 25, 2010, 6:19 pm
by ezernut9mm
that's exactly how my 67 bumper fits on my 66. i think the lmc bumpers are not correct, but i could be wrong.
Posted: April 25, 2010, 6:27 pm
by kstones63
ezernut9mm wrote:that's exactly how my 67 bumper fits on my 66. i think the lmc bumpers are not correct, but i could be wrong.
I agree that LMC is probably selling the 67-72 bumpers for the 63 trucks.
Does anyone sell a correct bumper for the early trucks????
Kevin
Posted: April 25, 2010, 6:51 pm
by Kid
LMC is selling the later bumpers for our trucks but so is DC and everyone else I talked to. I ordered one from LMC and sent it back because DC guarenteed me they had the correct bumper so I ordered from them and got the same one LMC sent me that I sent back.
Posted: April 25, 2010, 6:56 pm
by Uncle Skip
The correct bumpers for a 61-63 truck have three bolt holes on each side and in the front of the bumper in a triangle pattern. The 64-66 trucks have two on each side.... on top and one bottom.
U@ss
Posted: April 25, 2010, 7:12 pm
by Alan Mclennan
Mine is supposed to be of a later model!, but it seems to fit better!,
well slightly better!
by Kid
Skip, the 67-72 ones have the same bolt pattern as the 64-66 but they dont fit the front lower gravel gueard like the Orig on our trucks
Posted: April 25, 2010, 7:23 pm
Unless somebody ever tools up something new I am afraid our choice is to find good painted bumpers and have them chromed.
I am not sure even those are a whole bunch better though.
Posted: April 25, 2010, 7:54 pm
by jkimbrel65
I solved this problem on my 62 by cutting 1 1/2" off the frame and moved the bumper in
http://fordtruk.com/forums/album_pic.ph ... user_id=28
Posted: April 25, 2010, 8:29 pm
by kstones63
That is an idea that I might have to check into. Yours looks a whole bunch better than mine does.
Alan. yours still looks better than mine does. Mine doesn't have hardly any curve to it.
I know where there might be a couple of stock bumpers to get. If I can get one of these and have it straightened and chromed, it might be the way to go.
I am going to a chrome shop tomorrow that does bumper repairs and see if they can put an arch in this one and rechrome it.
The next option is to start to slice and dice to make it fit. I am thinking to cut the top so that I can make it curve and then weld up the slices. Then it would have to go back to the chrome shop. This will be a lot of work but I can then make it match the gravel guard curve.
Thanks,
Kevin
Posted: April 26, 2010, 5:39 pm
by kstones63
I took the bumper to a chrome shop that straightens bumpers today. They checked it against the template that they have and it needs the outside edges bent back 1/2" - 3/4". That would explain why it doesn't fit. It is a 67-72 bumper according to their pattern.
They are going to bend it for me, let me pick it up, check it and bring it back to be bent more if needed and then rechrome it.
He also said that if it isn't right, I could bring the bottom gravel guard down and he will bend it to match that curve perfectly.
The bill should be about $140. Now if I can get LMC to pay that bill for me, that would be great. LOL
Kevin
Posted: April 26, 2010, 6:22 pm
by Max
$140 including chroming it again? Are they selling drugs on the side? That's a steal!
Posted: April 26, 2010, 11:18 pm
by kstones63
Max wrote:$140 including chroming it again? Are they selling drugs on the side? That's a steal!
I thought that was pretty cheap. This place has been probably the largest chrome shop in Phoenix. When I was there today, I only saw 3 people working in the place. I guess that they are pretty slow right now. So now I will take the door handles and buttons to be rechromed.
Kevin
Posted: April 27, 2010, 12:38 pm
by 64 f100
I've seen 61 to 61 replacement bumpers with the right curve . I even have on NOS one, with a rust spot on it. I tried several times to sell it, but have now decided to keep it for a project sometime. Just wondering who makes the 61 to 61, and why they could not be persauded to make these withour holes. We could drill our own. If not that why not just make the 63 with 64 holes. Ford did the upgrade to the 67 bumper years ago, as they did with the tailgate. When you ordered the part that is what you got. I do think the Ford bumpers may fit a little better, but not by much.
Your bumper has frame or brakcet problem, I've sure. In the picture you see how it almost seems to curve in in the middle. I theinkyou truck has been ran into something in it's previous life. You need to take the bumper off and a staight edge accros the two brackets. I don't know for a fact these should be slightly curved towards the outside but if these are not at least straight even with each other ,then you need to straighten these, which should help.
Posted: April 27, 2010, 1:44 pm
by Obsa
Just a thought, would it not be easier to modify the gravel shield to fit the available bumpers? I know it would not be 100% correct but paint is way less costly than chrome.
Posted: April 27, 2010, 3:17 pm
by Gritsngumbo
kstones63 wrote:Max wrote:$140 including chroming it again? Are they selling drugs on the side? That's a steal!
Kevin
If they would straighten (or curve) and chrome a bumper for $140, I'll bet the members here would cover them up with work. Just sayin'
Posted: April 27, 2010, 8:37 pm
by Garbz
No one makes the correct bend bumper. All are generic fit all type.
Garbz
Posted: April 27, 2010, 8:43 pm
by UNIFAN
Gritsngumbo wrote:kstones63 wrote:Max wrote:$140 including chroming it again? Are they selling drugs on the side? That's a steal!
Kevin
I agree with Grits. I always find an original bumper and have it chromed which isn't easy or cheap. I would be a canidate for shipping them a new bumper to chrome if it turned out to fit properly. I may be one of the only guys that this really bugs though. Just hate seeing a killer truck with this bumper on it.
Posted: April 27, 2010, 8:58 pm
by ezernut9mm
67 bumper on a 66. looks horrible.
(btw, it's mine so i can say that. lol)
