Page 1 of 2
When should my Generator Light be on?
Posted: May 5, 2010, 9:26 pm
by Stephen
I've got a '64 f100 223 and my generator light on the dash is on during idol it usually goes away when I give it gas, usually. Should it be on then or should it only come on when there is a problem?
Posted: May 5, 2010, 9:36 pm
Aside from the generator getting weak it could be caused by;
bad battery
loose belt
too low idle
regulator contacts getting bad (won't carry enough current)
or a combination of the any of the above in small measure.
Generators are a little tough to come by and so are re-builders for them.
There is a place here in Omaha that does them and will ship them back out says up to $130 + shipping depending one what it needs.
I will post the info for the place in the Hints as soon as I remember to bring their card in out of the Jeep one of these days.
:roll:
Posted: May 5, 2010, 9:42 pm
by BarnieTrk
If it is engine is running, the light should not be on.
The light is telling you that the generator/alternator is not doing a proper job of charging your battery.
First thing I'd check is the drive belt.
Is the belt tight or is it slipping and/or squealing?
If the belt is old and glazed on the V sides, then tightening may not do the trick.... a new belt may well be the fix.
If a new belt snugged up doesn't put the light out while idling/running, then there is an electrical problem elsewhere.
Good Luck & keep us posted on your progress!
BarnieTrk
The list
Posted: May 5, 2010, 9:57 pm
by Stephen
I have changed the following:
1. Plugs
2. Coil
3. Points
4. Wires to the Coil
5. Battery
6. Battery wires
7. Belt (it might be a little loose)
8. I rebuilt the carb today and I have started messing with the idol on the carb...what rpm should it idol at?
Posted: May 5, 2010, 9:59 pm
by Stephen
I plan on changing the generator to an alternator at some point...right now I've been in a rush to just get it running reliably so I can get it to my Dad's shop in Tennessee.
Posted: May 5, 2010, 10:11 pm
by bird55
FYI, the gen can be repaired just fine before you go jumping out to do an alternator. IMHO cheaper and easier than an alternator for that setup.
I have the same yr and engine.
Just got my gen repaired like new, new belt, works perfect. make sure you try to tighten that belt up a bit, as suggested.
Carpenters also has a rebuild kit so you can do it all yourself.
One more thing, if you've been messing with the carb, you may have the idle to low.
Posted: May 5, 2010, 10:18 pm
by bird55
Here's who did mine. Seems like it was $60. Wasn't much more or I'd remember.
Auto Battery & Electric
1026 E 4th Street
Tulsa, OK 74120
918-584-5555
Posted: May 5, 2010, 10:19 pm
by Stephen
My understanding is the generator won't be able to keep up with any accessories I might want to add in the future- radio, lighter socket, maybe an a/c at some point. I plan on keeping any of the original parts no matter what, it's good to know that the generator can be rebuilt.
Posted: May 5, 2010, 10:21 pm
by Stephen
hmm, that doesn't seem too bad...I'll mess with the idol and belt tomorrow and see if I can keep the light off :D
Re: The list
Posted: May 5, 2010, 10:30 pm
by BarnieTrk
Stephen wrote: I rebuilt the carb today and I have started messing with the idol on the carb...what rpm should it idol at?
I like to set my 390 idle at about 800-900 rpms when warm. I doubt that it makes a difference that your engine is a 223 I-6.
I will further say that if the oil pressure gage is bouncing the needle, then the idle is too low...
With the truck running down the road, I'd dare to say your generator SHOULD be able to supply ample power to run the headlights, a standard radio, windshield wipers AND the defroster fan without the dash light coming on. However, running extra aftermarket/non-OE electrical stuff would be very iffy.....
BarnieTrk
Posted: May 6, 2010, 7:27 am
by Stephen
Thanks everyone, I'll putter around some more and see where I get with it.
Posted: May 6, 2010, 10:52 am
by macgiobuin
I concur with tightening the belt AND checking your idle speed.
Posted: May 6, 2010, 7:09 pm
by Spanky
Stephen, I have the same engine and issue you have however, I chose to go ahead and convert to and alternator. Caught a lot of hell with the 'ol bracket but found one at http://www.alternatorparts.com/Alternat ... kets_1.htm
Part No. A265 Haven't put it on yet cause I just got it in the mail but I think it'll work perfect!! Found this website from an old Ford tractor parts forum. Had good luck at these websites for 223 engines. Hope this will help you.
Posted: May 6, 2010, 11:00 pm
by Stephen
Got a shop manual at a swap meet and did a check on the generator...works great, it was putting out up to 31amps peak. So I started messing with the regulator (it's not original) and I think it's going bad. O'Reillys couldn't find a match any ideas? I did find out I need a series B.
Posted: May 7, 2010, 5:36 am
by F7BIGJOB
Stephen wrote:Got a shop manual at a swap meet and did a check on the generator...works great, it was putting out up to 31amps peak. So I started messing with the regulator (it's not original) and I think it's going bad. O'Reillys couldn't find a match any ideas? I did find out I need a series B.
Look at NAPA p/n : VR412 - Steve. : :lol:
I went to NAPAPRO link put in all info on your truck and it popped up [ they show one for alternator-pancake style, and they show one for the generator] hope this helps.
I tried to add link to pic,but when I tried to access it my session timed out :(
Posted: May 7, 2010, 5:42 am
by bird55
IF NAPA doesn't have a replacement. You can get an original style (if you care) from LMC truck. Sounds like your going to back on the road!
Posted: May 7, 2010, 7:22 am
by Stephen
Thanks! My wife got the mail yesterday and I got my LMC mag this morning. Yeah, I am trying to get it in reliable working order to drive it to my Dad's shop in Tn. My hope was/is that I can get it up to running reliably cheaper than renting a truck and trailer to haul it. Once there we'll start taken it apart all the way to the frame.
Posted: May 7, 2010, 6:29 pm
by fendermender
Where in tn a you going to do rebuild? If close maybe we can get together.
Johnny
Posted: May 7, 2010, 6:49 pm
BTW, the guy here in Omaha said that the $130 price is the high end = needs everything. Price goes down the less it needs. These people have been in business there since I can remember - best in the area.
Info is now in the "Hints" section.
Posted: May 7, 2010, 6:57 pm
by Stephen
It runs!!!! :) I was able to pick up a regulator and was reminded to polarize it then drove it to the tire shop and got tires. She ran great the whole time! Now, I need to replace the front motor mount...it's almost not there.
