Pics of gas door in 66 bed
Posted: February 17, 2011, 4:30 pm
by Jerry T
Here are some pics. The door and all accesories are off the 78. Since it is a 78 frame the tank is stock. I just had to modify my bed for the filler neck. I had to notch the floor and side about 2" deep and 4" high. make a cover for the notch.Then weld the door area out of the 78 bed into mine.
Posted: February 17, 2011, 7:02 pm
by MadMaxetc
Did the door match the profile fairly well?
Thanks for posting the pictures!
Posted: February 17, 2011, 8:32 pm
by Jerry T
Yes, the door matched very well.
Posted: February 17, 2011, 9:24 pm
by 19slick66
So you actually have a newer "78" frame under the cab and bed, Correct?
But to do the same on a non modified 66, Is he frame in the way?
Just curious.
Posted: February 17, 2011, 9:31 pm
by Jerry T
The 66 body is on a 78 4x4 running gear. The stock 66 frame is to narrow for the 78 tank. I am not sure what tank you would need to use.
Posted: February 17, 2011, 11:53 pm
by MadMaxetc
On the Dentsides they ran a semi-smashed hose between the bed and the frame. they have no more clearance there than slicks. The problem is the house you have to build for the bend in the tube.
I plan to fab my own tank and tube, just needed to find a doner for the door.
Posted: February 18, 2011, 8:30 pm
by Paul Merrell
Dan I am going to use a door from a Mercury Sable . I will have pictures tomorrow
Posted: February 18, 2011, 9:08 pm
by MadMaxetc
Paul Merrell wrote:Dan I am going to use a door from a Mercury Sable . I will have pictures tomorrow
Cool. I look forward to it.
Posted: February 20, 2011, 3:42 pm
by Paul Merrell
The door turned out nice but the inside where the neck fits thru is plastic . Not finish yet maybe next Saturday. http://fordtruk.com/forums/album_pic.ph ... user_id=62[/img]
Posted: February 21, 2011, 8:35 pm
by tomrooster
Gas door out of a Bronco but that wasn't a wise choice because the cap seals tight and no air can get in unless you leave it loose. Tom
Posted: February 21, 2011, 9:03 pm
by Jerry T
That is a nice job. I wouldn't have thought about putting inside the bed.
Posted: February 23, 2011, 1:30 pm
by markzieglerinsd
What year Bronco is that fender well from? I love the look of that. Could you use a vented gas cap to prevent issues. What tank did you use? I love the look of this install and it actually looks pretty easy to do.
Mark
Posted: February 23, 2011, 8:21 pm
by tomrooster
Mark, I don't know what year bronco , I am using a 75 frame so it's a 75 tank, I don't think a vented cap would fit but I didn't try it yet and it wasn't to hard just time consuming piping it and getting it to look decent. Tom
