Posted: July 3, 2011, 12:24 am
by ezernut9mm
oh man, cut at least two then. you can always cut more. i'm sure they can bend the beams in half if they want to. also, ford trucks love a little negative camber so take that into consideration as well.
Posted: July 3, 2011, 1:20 am
by azjake
ezernut9mm wrote:oh man, cut at least two then. you can always cut more. i'm sure they can bend the beams in half if they want to. also, ford trucks love a little negative camber so take that into consideration as well.
Negative camber will cause wear on the inside of the tires. I always set the Fords with the solid twin I-Beams at 1/2 degree positive camber on the right side and 3/4 degrees positive camber on the left side. Toe is set a 1/16" in with bias ply tires and 0 to 1/32" out with radial tires. At least that is what I set them at in Illinois and Phoenix. Other areas in the world the alignment may be set differently, depending on road construction and conditions.
BTW, a lot of things will affect alignment. I once had to ask the owner of a full size van to sit in the driver seat while I aligned his vehicle. Since he weighed over 350lbs, if he was not in the driver seat when the van was aligned, the alignment would change and be off when he did get in and drove down the road. This would cause excessive tire wear.
Jake
Posted: July 3, 2011, 1:47 am
by ezernut9mm
man, just look at the billion e series vans of the 80's and 90's. they have huge negative camber. so do most of the f series trucks. i successfully ran a 68 with (unmeasured) negative camber for over two thousand miles and couldn't find any noticeable tire wear.
i would cut coils and run it without a thought again right now. in fact, i am seriously thinking about cutting the coils on my 67.
it's not ideal, but it can be done and ride and drive just fine.
i have also seen shops align trucks loaded as that is how they are driven most of the time.
Posted: July 3, 2011, 4:39 pm
by shocker998md
I did a coil in a half. Id do two if I was you.
Posted: July 3, 2011, 5:16 pm
by 65fordguy
How is the ride after the cut coil and re alignment?? I have heard mixed stories on rough riding and or bump steer issues.
Posted: July 4, 2011, 12:46 pm
by BMJ's 65
I took a coil and a half or two (I can't remember exactly) out of my 67 and had the beams cold bent at the local truck shop. Between that and the new bushings, it rides and drives great.
Posted: July 4, 2011, 10:58 pm
by ezernut9mm
my 68 rode out fine as well, but i did new shocks as well and probably that along with the lowering made lots of difference.
front end shop
Posted: July 5, 2011, 7:51 am
by okiewelder
what shop did u find that will bend them? I used the one that used to be on south 11 about 20 years ago for just general alignment stuff. I live up by the city how. Good luck and tell us how it goes when u get them bent
Posted: July 5, 2011, 7:54 am
by dotcentral
Great topic. I want to do this to by 66 and 71. I'm in charlotte, NC, pretty good size town, and it took forever to find someone that could align it. Everyone kept saying they didn't have the specs in their computer program. To many people just rely on the machine and computer to do the work for them.
Sorry about the rant.
Gas4Blood & others, please update & post pics of what you do. I'd rather lower my trucks this way than trust aftermarket lowering beams.
Posted: July 5, 2011, 8:11 am
by BMJ's 65
I'll search for some before and after pictures.
Posted: July 5, 2011, 8:53 am
by jamesdfo
Not sure if you will be able to view this without being a
61-66 Ford F100 Alliance group member, but this thread on the HAMB has the info you are seeking.....
http://www.jalopyjournal.com/forum/grou ... ionid=9079
If you dont belong, go here to sign up. Search for 61-66 Ford F100 Alliance
http://www.jalopyjournal.com/forum/group.php
James
Posted: July 6, 2011, 11:08 am
by Brian Taylor
I cut 1 and 1/2 coils out of my 66. It dropped the front about 2 and 1/2 inches.
No ill effects and the tires are still running true with no wear after 5K miles.
Posted: November 18, 2011, 5:45 pm
by Alan Mclennan
I have the Dream beams with 1 1/2 coils cut, handles better than before and rides better!, I have 255/60x 17" on the front!, it does sit a bit lower now tho!, it`s been 4 years now
Posted: November 18, 2011, 9:08 pm
by Power by Ford
I had cut 1.5 coils on this 66 and bent the beams you want to U them as close to the mount point as posible. I drove it for around 12 years and 70,000 miles with no issue. It drove very well.
Posted: November 18, 2011, 10:24 pm
by Alan Mclennan
gas4blood wrote:How is your camber after cutting the coils? Are they 6 cylinder or V8 coils? Looks great!
I`d say mine are 6 cyl coils!, as the bonnet emblem is a 6 cylinder flash and gear wheel!, the Clevo was added by PO, the camber was checked when I had it re rego`ed after the build, which still needs work!
I really do think the DJM beams are worth the cost!
Posted: November 19, 2011, 3:29 pm
by Power by Ford
You are correct they were 6 cylinder coils. Not sure of the spring rates though. Also getting the correct length good shock is critical to ride quality
