Radiator options
Posted: July 31, 2011, 1:33 am
by Leeroy
My radiator is doing it's job, but the fins are in very bad shape and it's got corrosions pretty much everywhere, let alone being a hacked up item out of a local falcon. I'd like to start looking at options before the australian summer, sooooo
Will later model radiators fit? 67-81 types are easy to get down here, but do they bolt up to the 61-64 supports?
Posted: July 31, 2011, 2:08 am
by Alan Mclennan
Leeroy, What I did was use a XW/XY radiator and faded up some supports similar to the OEM, in the pic you can just see a flat bar that goes across behind, or in front depends how you look at it
, the bolt on this side looks to be just above the battery terminal! , it has 2 hook shape brackets welded to it that go over the top of the top tank, the bottom is the same just upside down and uses the OEM rubber bushes.
Sorry I can`t do circles and arrows just yet!, but when I grow up I hope to be able too!
Posted: July 31, 2011, 2:18 am
by Leeroy
Hmmm that could be do-able, my inlaws are pretty handy with the welder and xy radiators are common. I was hoping the 67 onwards might be more of a bolt in job to save some of the fab work.
Posted: July 31, 2011, 2:27 am
by Alan Mclennan
I went with the XW/XY as they are made for Clevo`s! and easy to find!, notice I didn't say cheap?
FRONT HOOD TILT MOUNTS
Posted: July 31, 2011, 7:19 am
by jhewitt
I like those front tilt mounts, where did you get them and how much did it set you back? Are they working well and how is stability of hood going down the road? How does it mount at windshield end?
Re: FRONT HOOD TILT MOUNTS
Posted: July 31, 2011, 4:56 pm
by Alan Mclennan
jhewitt wrote:I like those front tilt mounts, where did you get them and how much did it set you back? Are they working well and how is stability of hood going down the road? How does it mount at windshield end?
I copied the design from a magazine article, and it is working as well as the day I fitted it. It rides well!, but I did put a couple of rubber bumpers on the cowl to stop some sideways movement on very rough roads, the original bonnet catch is used with any mod`s, the position/fit of the bonnet can be adjusted in about 3 locations if need be.
There are a few guy`s in the club making their own "Red" being one!, and Kevin has changed the design and is making them for people, here`s a link to my design!, if you have any problems let me know as I`m making another one at the moment!
http://fordtruk.com/forums/viewtopic.php?t=15604
radiator
Posted: July 31, 2011, 6:36 pm
by okiewelder
I have one from a 79 half ton with a 460 in it. It fit in the core support but, I think I had to redrill some holes to bolt it up
Posted: August 1, 2011, 1:44 am
by Leeroy
Thats the sort of info I'm looking for. My main concern is if it hangs down too low or anything at the bottom of the support getting in the way.
