valve cover track
valve cover track
I was talking with lance yesterday while we were working and he suggested seeing if we can run anything else down the VC track. We have put quite a bit of time and money into it just to use it on one afternoon. What else can we build/run on it to get more fun and use out of it. We could run Sunstar trucks if we wanted or if we don;t want to risk damaging them then can run ash trays or something like that also. Track width is only 11in wide so keep that in mind. Give me some ideas..................Kid
Re: valve cover track
I told Kid maybe some easy to remove part like an ashtray could be used.. to make a new class? Possibly solder on a long rail like end.. or bolt it to a board? It seems like those interested could have more chances to brake a RACE CAR if there were more classes to run...I even wondered about some hot wheel track and the 1/64th trucks ...
Hunter's 64
http://www.pinewoodpro.com/pinewood-der ... ctures.htm
http://www.derbymonkeygarage.com/
make custom pine wood derby cars/ slicks in a larger scale .wider track width
Danny
Danny
- Alan Mclennan
What about air breathers!, surely someone has done that before!!
- ezernut9mm
it might need some work before running again mac.
- Alan Mclennan
ezernut9mm wrote:it might need some work before running again mac.
AH Bugger!........................
track is done and now just needs painted
