Frame swap questions?
Posted: March 22, 2013, 10:18 pm
by brent460
I currently have a 66 short bed and should be picking un a frame from a 77 short bed soon. So what all if any issues am I looking at to mount the 66 sheet metal on to the 77 frame. Its a 4x4 frame if that makes any difference. Thanks for the help guys really appreciate it.
Re: Frame swap questions?
Posted: March 22, 2013, 10:54 pm
by totten
That be a nice upgrade. Hope you got the engine,trans.,with it. Cant help you,but someone will chime in. Tony
Posted: March 23, 2013, 10:07 am
by bruceandersson
The width of the rear frame section changed between the bump sides and the dent sides. If your running a step side not problem. If your running a style side you will have to move the mounting bolts. The rear bumper will also not fit without adjustment.
Posted: March 23, 2013, 10:23 am
by brent460
I've got a couple motors, transmissions, and transfercases to choose from so Im not worried about that part.
Posted: March 23, 2013, 10:26 am
by brent460
Good to know Bruce what about the cab mounts? Or the ones for the core support?
Posted: March 23, 2013, 10:33 am
the cab and front clip will bolt on just like the 65
bed as posted above
if you want your original steering wheel you need to find a 67-70 4x4 column
you also will need the 4x4 trans hump cover 67-79
Posted: March 23, 2013, 11:55 am
by brent460
So for the trans hump does that mean most if not all of the trans tunnel?
Posted: March 23, 2013, 12:27 pm
the removable cover
if your slick is a 3 speed or auto trans now you will need to cut the section out and install the cover
Posted: March 23, 2013, 1:30 pm
by brent460
Sweet! I think my dad has one of those covers laying around.
