Part number needed
Posted: October 13, 2013, 7:19 am
by Shillinghill
Hello Everyone,
I am working on a 65 F250 4wd vin F26JR685038 with a 240 I6. I need to find a fuel pump for it, when I ordered it from Napa the wrong one came in same thing at Autozone. Something seems different about the angle of the drive arm on the one I need. I still have the old pump but the PO had an electric fpump on it that worked but I would like to find a new mechanical.
Thanks for your help, Bill
Re: Part number needed
Posted: October 13, 2013, 11:19 am
by unibody madness
Here is a post by nummberdummy from the FTE site:
"A 240 is a big block 6 just like the 300, same block. You would want parts for a 300 if you have a twin I beam truck, easier to find.
If you're shopping on ebay, I typed in "ford 300 fuel pump" and they were all under $20 with most "buy it now"
This link has 5 available for $14.99 and a 30 day warranty.
http://cgi.ebay.com/ebaymotors/Fuel-...Q5fAccessories
Autozone can order them for $26.99 and even ship. Part # 60092
http://www.autozone.com/autozone/cat...=Airtex+Master
Also if you look at all the pictures, it would seem the difference in part numbers deals mostly with the fuel lines, some thread in some slip on, steel line, rubber line, etc... Find one that looks like yours or you can adapt your fuel lines to fit."
Hope this helps
John
Posted: October 13, 2013, 7:27 pm
by F7BIGJOB
Bill, NAPA p/n shows 4014 fits 65-69 240 & 300 filter on bottom. I looked up your F350- same listing, any #'s on your 350 that perhaps I can cross for you? az 60092 crosses to 4014 & M60092[ NAPA] Don't know if this link will show for you, did a comparison on the 2 p/n's:
http://www.napaprolink.com/compare.aspx ... 421910629+
Any luck on the F500?
Sent you an EMAIL
