Page 1 of 2
new to slick 60
Posted: August 19, 2007, 11:06 am
by az63pu
purchased a 63 pickup stepside 223 ci did the brakes f&r lookin for info on the clutch and carb. adjustments, can't get rev. when running and have to use the choke to keep her running....love some info, first ever ford. always a chevy or pontiac man.....
223 with a 4 speed on the floor, seem to be a solid truck pics to come later.
mark
Posted: August 19, 2007, 11:27 am
by Slick Fan
Welcome aboard! :welcome:
Not being able to get reverse with the engine running might be something internal...bent shift fork or something? :dontknow: It shifts into the forward gears fine?
Having to leave the choke on sounds like you've either got a big vacuum leak, or the carb's just plain dirty & half plugged inside from sitting.
Posted: August 19, 2007, 11:44 am
by Shawn F.
I had a 3 speed in my 66 and after owning it for almost a year I lost reverse and same thing... It was internal damage and pretty much needed to be rebuilt. May need to open it up and inspect it or make sure the linkage is doing it's job and going fully into reverse (even though you said it will when it's not on, at least that is how I read what you put).
As for the carb, it's probably time for a rebuild, gunked up inside, etc.
Posted: August 19, 2007, 11:54 am
by az63pu
seems to hit all other gears, there looks like adjustment nut down there by the belhousing, have to read which way to adjust it,......ordered a new fuel pump and carb. rebuild kit pick it up monday. has elec. fuel pump now. its a little holly on there now, this will be the first carb. rebuild i do, going to be a few firsts on this truck,
mark
Posted: August 19, 2007, 12:00 pm
by az63pu
oh, by the way thx. for the info . will update profile and everything else later this is kinda a cool sight,
mark
Posted: August 19, 2007, 12:13 pm
by Shawn F.
Cool deal. Yes my truck did the same, only reverse and if I remember correctly I called a few tranny places and asked a couple guys and they said it's interal with the gearing. Said something about a spacer of some sort worn out and its common on the older 3 speeds. I cant remember the correct name for the spacer or nothing since I do not know much about trannies. Someone else here should be able to help you further.
Posted: August 19, 2007, 2:58 pm
by cdherman
4 speed. Likely a t-98 Borg Warner. Usually a pretty tough tranny.
You are looking for reverse over to the right and UP?
I have a spare t-98 -- they were common -- if you are somewhere in the area, you can have it. I am not sure what shape its in though.
Better still is that the later t-18 and t-19 are bolt up replacements I think.
There are lots of "how to rebuild" t-18 and t-98 trannies out there. Becuase of the super low first year, the jeep guys use them extensively for rock crawlers.
Why did the PO switch to an electric fuel pump? Might indicate other troubles, but I am not a 223 guru.
The old 1bbl carbs are not hard to rebuild. But keep in mind that a worn out throttle shaft that is causing a vacuum leak will give idle trouble and a rebuild kit will not fix that. If the rebuild goes well, but the idle still is trouble, do a search for how to find vacuum leaks.
Were you the fellow over at fordsix.com? If so, glad you found you way here. There are probably a lot more 223s at this site than over there. I like that site a lot, but I have a 240, which is a totally different motor.
Posted: August 19, 2007, 5:58 pm
by Uncle Skip
And Mark, "Rock Ridge would like to extend a hale and hearty welcome to our new ah, our new, er ah, member" (is this "welcome" to obscure??)
ROTFLMBAO :lol:
Guess from your login name you're from Arizona. Rock Ridge was in Arizona, right guys?
You have some guys out your way so be sure to hook up with them.
We're all glad to have you no matter where you're from.
U@ss
Posted: August 19, 2007, 7:29 pm
by az63pu
.....well thx. for the welcome, Texas that's a fine state been there many of times....Dallas , just north of there, there is a place i tend to hideout, called Gunter, wonderful place, been here 20 some years, Ohio was home guess Chandler Az. is now.
mark
Posted: August 19, 2007, 7:58 pm
by Uncle Skip
Mark.
I know Gunter very well (except there really isn't much to know :wink: ).
A little bug fart of a town in North Texas.
You should see it now, times have changed.
Back in the day (early 60's) I had a serious girlfriend from Dallas whose parents owned a little place in Tioga on the east side of the lake. Spent many a nice cool weekend on her parents houseboat there.
We were students at NTSU and had to leave Denton to buy beer (or anything else for that matter).
Tioga was the obvious choice.
Anyway, glad you're part of the family now. Come on home to Texas one of these days.
Skip in Houston
Posted: August 19, 2007, 11:07 pm
by MadMaxetc
Good to have you mark.
If the carb is worn out (the shaft that is) let me know, you can have mine. Sort of like a welcome gift that you have to pay shipping on :D
I like the 223, but I was young and needed more power.
Good luck with the truck and keep us posted!!
Posted: August 20, 2007, 1:50 am
by Garbz
Are not all residents of Rock Ridge named Johnson? All except Mongo...
And sherrif Bart?
Garbz
Welcome from Phoenix.
Posted: August 20, 2007, 5:39 am
by 66fordtrucknut
Greetings from the far east, well the Eastern shore of Md.and fellow 223er, I love it, it's quiet, economical and dependable.
Charlie
Posted: August 20, 2007, 9:09 am
by fmartin_gila
Mark,
Glad to see you made it over here. Lots of good info & such here.
I posted either yesterday or day before Either here or on the performance 6 forums about the holly carb(boy do I have CRS), so this is kind of redundant. If the throttle shaft bores will allow you wiggle room, you will be wasting your time amd money to try to rebuild it. If you do rebuild it yourself, pay very close attention to all the adjustments and you will do OK. From past experience, I recommend setting the float drop adjustment a little short of what they call for(1/32-1/64). This will eliminate the slug getting cocked of to the side and will eliminate a flooding issue these carbs have. Also, if you can come up with a glass bowl, you will eliminate a seeping/leaking problem that sometimes shows up, the glass bowl wont seep or warp.
If you do need a carb, I will recommend Rod's Carburetor Repair Inc. 2718 W. McDowell #2 in Phoenix. (602)272-4992. When I needed to exchange mine, I got it from them and it has been working good since. If you get one from any of the Checker,Autozone,etc. you are taking a gamble as to whether it will work or not(have heard of people getting as many as four before they got one to work properly).
Fred
Posted: August 20, 2007, 9:24 am
by Uncle Skip
Garbz.
Yep.
All named Johnson except Sherrif Bart, Mungo, AND the Waco Kid.
U@ss (aka Headly Lamarr)
Posted: August 20, 2007, 9:40 am
by Max
You old timers must be talking about something in black and white...!
Posted: August 20, 2007, 10:13 am
by Garbz
U@ss (aka Headly Lamarr)Well, make sure you never get caught with froggie.......Or Lilli VonStup the tutenoic titwillow......
Nope no black and white involved in this movie...............Mongo love sherrif Bart....... :wink:
Garbz
This flick by Mel Brooks should be mandatory vewing for all sensitive types....
Posted: August 20, 2007, 10:28 am
by Max
I just figured it out... I'm just a young(er) idiot. :|
Posted: August 20, 2007, 5:37 pm
by Alan Mclennan
:welcome: Mark, your`ve come to the right place!,good advice and idea`s and other stuff :shock: .
Alan.
AAALLaaann LLLOOOOOVVVVEE LLLIIILLLLLLII :roll:
Posted: August 20, 2007, 5:56 pm
by Uncle Skip
More schnitzen grooven Scheriff?
Casey, you gonna serve schnitzen grooven at Slick Stock?
ROTFLMAO
Headley
