Done similar stuff
On the other hand.....
Engine in , new plugs, wires ,cap, rotor points
Carb linkage & choke cable hooked up
All new fuel hose & filter
Clutch linkage hooked up
Starter wire & ground strap attached
New wipers installed
Today's agenda...
3 new ujoints , carrier bearing & driveline & E-brake install
Exhaust pipe & new muffler
Drain & new oil in engine , trans , rear end.....
