65 & 66 common questions and modifications
Posted: July 16, 2006, 12:32 am
by MattsIASlickShop
we will add content to this thread as it pertains to the common modifications we have done to these trucks.
Power steering column swap Instructions:
http://www.fordification.com/steering-column.htm
Power disc brake upgrade page:
http://www.mongrelmotorsports.homestead ... discs.html
Don't have your hood fly up on you.
Posted: December 12, 2006, 11:30 pm
by MattsIASlickShop
Johnny Canuck wrote:Don't have your hood fly up on you.
Drill a hole in your emergency latch (Falcon shown but a slick is very similar).
use a hitch pin or padlock through the hole, and save expensive hood, windshield, and underwear repair
[albumimg]1117[/albumimg]
Posted: November 25, 2007, 3:51 am
by greythorn3
how common is the hood flying up?
Ray
Posted: November 25, 2007, 7:19 pm
by Rosati
Not very common. Usually it happens when the latch assembly is misajusted or worn.
Posted: August 4, 2008, 12:40 am
by 3ontree66
Every one of these I've owned has had the preverbial dent in the middle of the hood from a windshield kiss. Happened to me last week.
Posted: March 8, 2009, 11:29 am
by 64 f100
The hood coming loose is a more common problem than should be. Nothing like driving down the road at 70 mph to suddenly have to stick your head out the window so you can find someplace to pull off the road while you shut it down. Scare the hell out of you.and do some seious damage to the cowl and roof.
Posted: August 17, 2009, 6:25 pm
by dav
had my hood pop up no the "I" doin bout 85 or so not only did the hood get the windshield kiss marks but damaged the cowl as well
Posted: August 18, 2009, 7:53 am
by fmartin_gila
I installed a positive latched, inside the cab pull type setup on mine. Came from a 77 ? GM pickup. Just had to make a mount for it down in the hole. Works with the stock loop already on the hood. A side benefit is that as long as the doors are locked, they cant get under the hood.
Fred
Posted: January 16, 2010, 11:57 am
by macgiobuin
I installed a hood lock (chain w/lock receiver found on Ebay for about $5) for security. Also will stop the hood from surprising you out on the interstate.
Posted: March 8, 2010, 10:02 pm
by Paranoid!
I had a hood on a 1977 stepside fly up on me one early morning on the interstate!
Besides instantly scaring the s@#t out of me!!
Head instantly hit side window!!!Hard!!trying to look out
Coffee everywhere!!
Couldnt see under the dam hood!!!
What a morning...
Posted: August 19, 2010, 10:39 am
by craighill74
Damm I am now truly jealous. I can barley get mine to do over 60 with out complaining LOL
Posted: November 7, 2010, 3:29 pm
by nolabama
power steering sticky is giving a 404 url not found error
Posted: January 5, 2011, 7:05 am
by DV65CustomCab
As much as I hate to refer people to "that other site", here's an article with photos on converting the repro core support to fit a '66 which would also be similar for a '65.
http://www.ford-trucks.com/forums/10232 ... 6-use.html
Re: 65 & 66 common questions and modifications
Posted: December 25, 2011, 4:03 pm
by JOELHEWITT
I drilled a hole as stated and keep a lock in mine, it's no problem to stick my hand in there to unlock.
Posted: February 21, 2014, 1:18 pm
by jfm
macgiobuin wrote:I installed a hood lock (chain w/lock receiver found on Ebay for about $5) for security. Also will stop the hood from surprising you out on the interstate.
Could you perhaps provide an item number or link? I was not able to find what I thought you described.
Posted: February 21, 2014, 1:22 pm
by jfm
craighill74 wrote:Damm I am now truly jealous. I can barley get mine to do over 60 with out complaining LOL
Mine will do 70 to 80 and get 20 mpg. Somebody before me put a 2.75 axle under there. Don't ask it to pull more than itself, though. As far as pulling goes, as an ex-partner liked to say, it wouldn't pull a greased string out of a cat's you-know-what.
Posted: March 28, 2014, 9:01 pm
by Liberty
Is there a photo of where to drill the hole in the emergency latch? Also what keeps the emergency latch from moving?
Posted: March 28, 2014, 9:09 pm
by Toyz
Answer to both questions: depends on the lock! Find a big lock which will not fit through the slot when mounted laterally across the emergency latch, mark and drill a hole low enough for easy access, but not low enough to be easily visible. The latch will be able to move somewhat, but will be unable to dislodge itself from the slot.
Posted: July 15, 2014, 9:09 pm
by DJ Bill
Here's the current URL for the power steering into 65-72 trucks...
http://www.fordification.com/tech/powersteering.htm
Posted: July 31, 2014, 4:41 pm
by 69supercj
I just used a small aluminum carabiner instead of a lock to keep the latch from pulling through the hole. Works and is real easy to remove but obviously wont provide security against theft.
