Body differences
Posted: December 9, 2006, 11:00 pm
by iontkendall
I am considering buying a 1961 f-250 4x4. What I need to know is what body parts will interchange between 61 and 66. I have a 1976 f-250 4x4 that I can use the drive train out of (390,4 spd. trans,205 transfer case,d-60 rear and d-44 front). I love these series of trucks but I am partial to the looks of the 65/66's.
Thank you
Ion Kendall
Posted: December 9, 2006, 11:34 pm
by Johnny Canuck
Ion welcome to the club.
a 61 F250 is going to have a box that matches the 57-60 trucks. Correct for all F250's the whole run of 61-66 slicks too.
The whole front clip, i.e outer fenders, front grille face, hood, bumper and rock guard can be swapped with any other year. So if you wanted, say a 66 front grille and upper valence on a 61 you could do that.
The inner fenders and radiator support are different on the twin I beamed trucks of 65 and 66.
So, that might get you started. The cabs on the F250 4x4 are all the ones from the big trucks for 61-66.. the one with the battery box in the floor under the passenger's feet.
Posted: December 10, 2006, 9:08 am
by DV65CustomCab
JC, the 4x4 front fenders have a larger opening also. Not that the 'normal' fenders may not work, but it's something to be aware of.
Posted: December 10, 2006, 10:08 am
by FORDBOYpete
Yeah Welcome to Slick 60s. . . . .
The 61 4X4 will have same major body parts as 61-64. The later 65 & 66 or Generation II Slicks have slightly different body parts, and completely different chassis/ frame parts. The 61-64 generally speaking are sittting on 57-64 style chassis, as least in 4X2 versions. There are more cross over features among the 4X4 chassis however between the 57-64 & later.
The real difference is the 65 & later will virtually bolt onto a 65-79 chassis with a few tweaks here & there while the 61-64 will not. Altho it may be accomplished with a some fabrications creativity & improvisation.
FBp
Posted: December 10, 2006, 12:10 pm
i have done both conversions.best and easiest is a 65-66 2wd f100 or f250 on a later 67-up frame, pretty much a bolt on as Pete says.
putting an early 61-64 or 61-66 f250 4x4, f350 and up cab on a later frame requires much more work, i am almost done with one now
[albumimg]565[/albumimg]
[albumimg]563[/albumimg]
[albumimg]561[/albumimg]
[albumimg]564[/albumimg]
this is the easy one, 65 f100 on 68 frame
[albumimg]568[/albumimg]
Posted: December 10, 2006, 11:36 pm
by iontkendall
Thanks for all the great info. This is a great site with great people willing to share knowledge and insight.
Ion Kendall
Posted: December 11, 2006, 12:40 am
by Johnny Canuck
I should have qualified what i said about F250 beds by saying "for 4x4's". I believe F250 2wd's after and including 1964 have the matching styleside bed.
Posted: December 12, 2006, 9:04 pm
by iontkendall
O.k. So now I am looking the 1962 f-250 4x4 on e-bay. My question is will a 65/66 cab, bed, fenders (inner and outer), grill etc... bolt on to this chassis?
Thank you
Ion Kendall
Posted: December 12, 2006, 9:12 pm
by Paul Merrell
If the bed of the 62 has round rear tail lights the 65,66 bed will not fit the chassis, wheel base is shorter than a 65,66 long bed but longer than a short bed. Ford did some crazy things with the 4x4 I think the cab from a 65,66 will fit the 62 frame but not sure! but the fenders and grill will bolt up with using the inner fenders from the 62
