standard shift columns
Uncle Skip
Post by Uncle Skip »
Iceman posted this in the truck talk forum, but I thought it would be good to add it here for future reference.
From Fordification
http://www.fordification.com/tech/3spd-column_01.htm
U@ss
slickmainer
Post by slickmainer »
what part in the column needs replace to stop the problem described below...(maybe its not a problem)
I can grab my steering wheel and move it up and down a bit, and it feels like the shift tube is moving inside the column. It's a small amount of play but I dont know if that is normal or not?
--Gregg--
you can't get there from here
most likely the bearings are slightly worn.
you can loosen the bottom clamp and move it up toward the tube, this should help until you get new bearings
