army green slick???
ebentraywick
army green slick???
has any of u guys or ladies seen a slick with army green paint im thinking of painting my truck that color
owning a slick.,,, priceless
1961 ford f350
1959 ford f100. not a slick but still goood looking
1961 ford f350
fmartin_gila
- unibody madness
I have one in that color. not sure it will stay that way. it needs some work and the paint ain't grand.
sent you a pm about t-case let me know if you got it
john
john
Military painted slicks
To Fred Martin and anyone else who may have photos of military marked slicks I would appreciate any information on paint and markings. I have the remains of a 1966 F-250 flat bed truck with the military 19.5 inch wheels and one ton type front fenders. It was a 6 cylinder with New Process 4-speed transmission with the larger Camper Special upgrade wide brakes front and rear. If I ever get around to putting it together I would like to paint it close to original military style with glossy olive drab green paint and yellow lettering. The sheetmetal is OD green inside and out and has the original military data plate. Any info greatly appreciated.
Don--aeromech
Don--aeromech
fmartin_gila
Re: Military painted slicks
Don,aeromech wrote:To Fred Martin and anyone else who may have photos of military marked slicks I would appreciate any information on paint and markings. I have the remains of a 1966 F-250 flat bed truck with the military 19.5 inch wheels and one ton type front fenders. It was a 6 cylinder with New Process 4-speed transmission with the larger Camper Special upgrade wide brakes front and rear. If I ever get around to putting it together I would like to paint it close to original military style with glossy olive drab green paint and yellow lettering. The sheetmetal is OD green inside and out and has the original military data plate. Any info greatly appreciated.
Don--aeromech
I don't recall reading/hearing of a factory-optional "Camper Special upgrade" for the brakes on a '66.
Did you mean upgrading your '66 to the larger '67 brakes?
BarnieTrk
Sorry, Gents.... I'm having some computer difficulties....
Please bear with me.........
....ENOUGH ALREADY!!
DANG INTERNET BUG!
- charliemccraney
Bernie: drop the mouse and step away from the computer!
Wow! what a great video of the US Army marked Cummins 4X4. Mine is 2wd and likely will be 460 powered.
I may be wrong about the "Camper Special" upgrade terminology (maybe it was Heavy Duty) but there was an heavy duty brake option for F-250 trucks in '66 and likely in '65. The stock brake shoes are 2 inches wide and the HD upgrade shoes are 2 1/2 inches wide. The fronts are an easy swap out. I just replaced from king pins out to get the longer spindles and drums. Rears require an entire Dana 60 axle change as the backing plate mount flange bolt holes are different.
Worth while upgrade--makes a noticable difference, especially when carring a load.
Don-Aeromech
Don-Aeromech
- Gary Seymour
- ezernut9mm
here's one (plus a couple of fridges for good measure):
factorystock
If the factory made it, sooner or later, I'll find it.aeromech wrote:To Fred Martin and anyone else who may have photos of military marked slicks I would appreciate any information on paint and markings. I have the remains of a 1966 F-250 flat bed truck with the military 19.5 inch wheels and one ton type front fenders. It was a 6 cylinder with New Process 4-speed transmission with the larger Camper Special upgrade wide brakes front and rear. If I ever get around to putting it together I would like to paint it close to original military style with glossy olive drab green paint and yellow lettering. The sheetmetal is OD green inside and out and has the original military data plate. Any info greatly appreciated.
Don--aeromech
