Wicked radiator damage
sorry guys, have to link to pictures today. camera's on the fritz.
first off, the gory details:
http://www.facebook.com/photo.php?pid=4 ... =621629431
whoa! those fan blades are stiff, i have no idea what would make it bend that radically against the turning direction. if it was spinning and it hit something, wouldnt it have bent the other direction? it didn't hit anything in the engine compartment, there wasn't anything in its way and nothing else was tore up. regardless, the radiator ist kaputt, wondering if you guys have insight on perhaps what would cause the fan to bend like that...
Here are several Ford fans including the flex blade. They were pretty noisey.
http://www.santabarbaramusclecars.com/t ... page-3.php
Jim
That could be a mystry that may never be solved if it was perfectly straight before the failure. Something had to get in the way to cause that kind of damage.
Michelle
Brian Taylor
I had the exact thing happen to a vette I had. Replaced the readiator and was lost in what could of happened. About 2 weeks later went to find my large breaker that I used for turning the engine and realized that was on the frame and bounced off during the drive and bent the blade.
1966 Ford F-100 LWB 300
lost a blade into the hood one time. found out later there were some older fans prone to failure.they are also mentioned in one of the Steve Crist books.
not sure if it was actually one of those but i got lucky as all the damage was the slice in the hood.
we were coming back from Anchorage and got to the turn in the highway where at the time was a traffic light.
a few miles back we heard a noise, thought something from the road hit the bottom of the cab. the engine was vibrating quite badly at idle.
we went slowly to the wal-mart lot a couple more miles away. when i opened the hood, the blade fell out of the hood and light shined thru the gash.so we stooped at the auto parts and they had one universal racing type flex fan. wallet lightened $40 or so i changed it out in the parking lot. of course theres 17 fans 50 miles away at home, but doubt i would have made it.
we took some pics later at home,(i cant find them) took duct tape and wrote "OUCH" in permanent marker and taped over the gash.
- 6166 Junkyard Dog
I have a radiator in the junk pile brand new from a guy with a 65, He bought a new raiator then BOOM, he said something flew up from the bottom he heard then steam and water on ground, he had that same 4 blade steel fan , I sold him a 5 blade Ford Flex Fan used radiator and he was on his way
Kathy
Now Cooper will try his best
I don't think an animal hit on the road would cause these fans to bend like that. Maybe a large rock or such item hit by a tire and flung int the fan, but you would surely feel that. What an enigma!
1965 F100 "Papaw's Pride"
I was a line mechanic @ a FORD dealer in the early '80's.FORD was doing a recall of clutch fans due to several fatalities caused by fans coming apart and blades flying off and striking someonewhen the hood was opened and the engine was running.If memory serves the recall involved FORD cars and trucks from 1973 ish to 1978 or'79.Since then I have NEVER trusted them(an ounce of prevention...)I always cringe when I see someone lean over an engine and race it to 3 or 4 thousand rpm...
Dave
Dave
A guy that used to work for my dad had a fan blade come apart in his face. Lost an eye & took a chunck out of his head. I never race the engine from the front!
On another note, earlier in Rusty's life, with my brother at the wheel, the motor mount let go and the engine rocked over letting the fan hit the core & doing the same damage. Check your mounts.
i think we have winner!!!!!!!!!!i was going to post the same thing till i got to the bottom.....ck your left motor mount really close.....it most likely hit the bottom of the top tank,bent the blades and eat up the rad......65COOL wrote:I had a motor mount go bad it did the same thing made one heck of a noise.i think it was the driver side
the last time that happened to me,bambi had something to do with it!!!!!
smith and company auto
1600 crump street
richmond va 23223
804 648 8737
07 PINKS WINNER @ VMP
IHRA CHASSIS INSPECTOR
1600 crump street
richmond va 23223
804 648 8737
