Rear brake self adjuster cable
- charliemccraney
That approximately 12" long cable that runs from the spring post at the top to the self adjuster lever thingy toward the bottom.
Napa doesn't have a listing for '61 but they do have one for a '64. Are they the same? For that matter, will the self adjuster kit be the same between the two?
Lawrenceville, Ga
1961 F100 Unibody
1961 F100 Unibody
early star adjusters were manual, the teeth are bigger, so in order to change to self adjusters you need all the pieces.
the cables and pieces from later years will fit and work.
- charliemccraney
- ezernut9mm
yep. just went through this on my 66. i bought all the pieces to convert to self adjusters through o'reillys auto. cables, stars, new springs, etc.
- Uncle Skip
- ezernut9mm
that too. i had to scrounge one up at the local u pick it. i think it was off a 78. i would save all those i could find too.Uncle Skip wrote:Ice, et al.
The only part that they don't reproduce is the "spreader" with the square spring on either end, just under the wheel cylinder. Better save that one.
They're getting hard to find.
U@ss
fmartin_gila
When I installed the disks on the front of my 62, I also got all the hardware for the later model and installed the self-adjuster setup on it. You will have to make a new slot in the backing plate on one side so you will be able to back it off if you ever need to as the star wheel lines up with the slot on one side but not the other.
Fred
Fred
do not have one, all my trucks are manual adjust.MyDads64 wrote:Iceman, can you post a photo of a rear brake with the self adjusting cable installed?
Thanks,
pretty sure if you go to www.fordification.com you will find Keith has good exploded diagrams of the 67-72 which are the same
