urethane reducer in enamel
jamon8
Post by jamon8 »
It works
pics soon if I can post
someone help
Jamon8.com
olliesshop
Post by olliesshop »
Some advice on posting pictures (cause we all love pictures!!!), you first have to upload to to an online site, like Photo Bucket. Then to get them to show up in the posts you click on the "Img" box in the upper right of the edit screen then insert the URL of the picture online (by right-clicking on the on-line pic and copying the image path) then pasting that after the first "Img" then hit the "Img" button again and you should be all set.
Then hit the preview button at the bottom of the edit screen to see what it looks like and if if looks OK then hit the Submit button.
I hope this helps, since it's not very straight forward the first few times.
Tim - 1961 F250 Uni
i have found it easier to type in the tags.
otherwise only the front one is inserted and you have to preview after every pic you put in in order for the back one to be inserted.
when using pics from photo bucket it is not necessary as if you copy the img code and paste into the post the tags come along for the ride.
