carburator ??????
64slick
carburator ??????
Post by 64slick »
I have found out that the 1 barrell carb on my 223 is not the original, it seems that somebody took a carb from a 300-6 and put it on my 223, now my question for you carb experts, I'm using alot of gas, only 9.5 miles to the gallon to be precise, I'm sure that the jet for a 300-6 verses a 223-6 are different, is there any way to calculate which would be the right jet to use, for a 223.
64slick (Tom)
66fordtrucknut
Post by 66fordtrucknut »
What carb. is it? My 223 has a holley 2043 1 bl and get about 17 hwy /15 city with 3.70 rear gears.
Charlie
62' SWB uni 223
66' F-100 Short/wide 352
78' F-350 dually dumpbed 400
12' F-150 5.0 3:73 LS
64slick
Post by 64slick »
223-6, carter 1barrell off of a 300-6, with 3:89 gears :oops: sorry I didn't post that
64slick (Tom)
jakdad
Post by jakdad »
Sounds like it may have a bad power valve. Good luck.
Jim
bobenhotep
Post by bobenhotep »
i found a bunch of carb manuals on oldcarmanual.com
My '63 short wrongbed
"The Iron Rhino"
-300-6 choke tube repair
-duraspark II/ HEI
-turn signal indicator fix
