yet another way to mount a pedal operated brake light switch
bobenhotep
Post by bobenhotep »
this is my brake light switch.
9009
i drilled a hole behind the dash and mounted it to work off of the bump stop bar on the brake pedal. if you strip the wires out of the harness under the hood and route them through to the inside, they will just reach the top of the switch. then you can put spade connectors on them and be done.
My '63 short wrongbed
"The Iron Rhino"
-300-6 choke tube repair
-duraspark II/ HEI
-turn signal indicator fix
