and yet another method for a brake light switch
Uncle Skip
Post by Uncle Skip »
Ron Francis sells a special low pressure hydraulic switch (the inline style) to replace the old one - direct replacement - and has a nifty plug that goes over the switch posts.
It only takes 25/30 pounds of pressure to activate instead of the old style that takes over 100 pounds.
Look at SW32
http://www.ronfrancis.com/products.asp?dept=28
Cured my intermittent brake light problem and I didn't have to custom rig a mechanical switch under the dash.
I like it. :D
U@ss
ezernut9mm
Sweden
Post by ezernut9mm »
very interesting. thanks for posting that skip.
tomrooster
Post by tomrooster »
They don't seem to last very long with silicon fluid might be OK with regular brake fluid. Tom
1966 F 100 w/391 ft
1965 F 100 project
1958 Edsel Pacer Convertible
1953 ford Customline 2 door
1952 8N
1967 triumph Bonneville
Uncle Skip
Tom... this switch is silicone friendly.
That's what I had a problem with in the first place.
U@ss
moondog
Post by moondog »
Skip,
Thanks! I am going to get one.
Roger
Haus
Post by Haus »
I've done a couple of the SW 76 type. Had to build a small bracket from scrap metal laying around. Works pretty good and eliminates the need for wires hanging out your firewall. I've got a new truck that I don't plan to go all out on so I'll keep this part in mind.
All my tools are hammers except screwdrivers, those are chisels.
1966 F-100 2WD
351 Cleveland **no its not a 351M**
C4 trans
3.50 rear end
