leaf spring removal problems
Seems easy enough. Right? trying to replace the 45 year old rear leaf spring bushings. I got all six nuts off with not problem last week . Soaked every thing for a week. Had a friend come over today and the bolts will just not come out. We tryed prying and hammering. Bolts spin,but wont back out...may be rusted to sleeves...not sure
I'm not gonna use a torch...me and a torch, nothing good can come of that....
Any tips or anything I'm missing here?
thanks truckster..question
I will get hold of a sawzall,but how did you do it? I cnat seem to even get a gap between the bolthead and the leaf to get blade in there...of did you do it another way I'm not thinking about?
likely they are rusted to the center sleeves and the rubbers are loose from the outer sleeves.
if you dont like the torch then you must carefully cut between the brackets and the spring eyes
- Uncle Skip
Cosmo. First, have you removed the rear end?
Do you have the springs "unloaded".
By that I mean do you have the frame jacked up so there is some slack in the hangers.
Even with the rear end still attached to the springs, you can do the following. Its easier without the rear end but what I suggest is:
1. Drop the front of the springs down. Remove the bolts from the front.
2. Raise the frame so the spring eye clears and drops down and you have some room to pull the rear end and springs forward - that will let you access the spring hangers. They are the two flat pieces of metal that connect the spring eye to the frame mount.
3. At this point, if you can't drive the bolts out of the spring eye or the spring mount, cut the two flat pieces with a right angle grinder or a fire wrench.
4. Once you get free access to the stuck bolts and they don't have any pressure on them, they will come out a lot easier.
A new spring hanger kit is available at Carpenter and others complete with the bushings, hangers and bolts for around $20.
U@ss
U@ss
- Uncle Skip
Duke. After 60 years, the bushings WILL BE pounded out of the spring eyes.
Go ahead and pull the springs and get them replaced.
And remember, the springs have a front and rear so pay attention when you take them off.
U@ss
U@ss
- unibody madness
I agree, after unloading the weight off them, run a nut back on part way and wail on it with a bigger hammer, then use a big center punch to finish the job.
all of mine have come out that way, but I sprayed mine with a 50/50 mix of atf and acetone a few hours prior.
Now removing the bushing from the spring is a different matter for which there aren't enough punctuation marks on my keyboard.
john
john
- Alan Mclennan
John, that's when the sabre saw comes in handy!, cut the crush tube in half and then flog the living crap out of it!
- 66fordtrucknut
sometimes thats the best way.DukeRoche wrote: other then a torch
i prefer not to, helps to have an impact wrench that spins the bolts enough that with pb blaster and a little heat (even from a propane torch) you can thread them out.
- Alan Mclennan
Duke, If you've got the bolts out!, and don`t have a saws all!, get your hacksaw take the blade off , put the blade through the bushing and put the blade back in the hacksaw!, now put 2 cut`s through the wall of the bushing about 1/4" apart, then drive an old screw driver down beside the bushing to squeeze the gap together, which will reduce the size of the bushing and it should come out easily!, SHOULD!.
wait till you try and get the rubber out!
That`s real fun right there!
William-in-St George
Hack saw
Dang good idea to put a blade in the hole and then put the handle back on!!! I wraped the blade with tape!! Wish I'd thought to put the handle back on DUHHH!
William-in-St. George
