Generator light on?
Casey
Generator light on?
Post by Casey »
So the generator light went on tonight when I turned off the ignition of my '64 with a 223. The light stayed on until I pulled the negative cable off of the battery. Slight electrical smell under the hood. Any ideas?
CANDY IS DANDY BUT LIQUOR IS QUICKER
RlCHARD CRANlUM
Post by RlCHARD CRANlUM »
Either the voltage regulator went, or the generator went, and took the voltage regulator with it. I had a similar problem with my 62 292. The light came on, I revved up the motor, and the light went out. Eventually it came back on for good. I ended up with a rebuilt generator and new voltage regulator.
bobenhotep
Post by bobenhotep »
the cutout points are staying closed on the regulator.
you need to adjust the regulator, or you will burn something up. mine did that, but then i replaced the generator with an alternator.
My '63 short wrongbed
"The Iron Rhino"
-300-6 choke tube repair
-duraspark II/ HEI
-turn signal indicator fix
