how to install a "hood brace cushion"
63uni
Post by 63uni »
How to install a "hood brace cushion"
Has anyone replaced one of these as seen in the LMC catalogue
63 F 100 unibody :dontknow:
64low-n-slow
Post by 64low-n-slow »
When I re-did my hood I cut out the braces, sandblasted and coated everything inside and welded them back. The cushion was stapled to the braces if I remember correctly. Instead of replacing the cushions I used a 2K seam sealer to keep the outer skin from buffeting. 3M makes a 1K urethane sealer that you could shoot into the gap and get the same result.
Hope this helps...
63uni
Post by 63uni »
I think that's a great idea, I will do just that.
Thanks :cheers:
