Horn(s)
bmcgc
Horn(s)
Post by bmcgc »
Scored a couple horns today at the P-N-P. One off a 63, the other off a 71.
How many horns belong on my 66 and where are it/they mounted?
1966 F100 (Mine)
1965 Mustang (Hers)
1965 Mustang (Hers)
1998 1100 Aero (Hers)
2001 1100 Aero (Mine)
Wish List:
Win Indy 500
Ask Elvis WTH he has been
ezernut9mm
Sweden
Re: Horn(s)
Post by ezernut9mm »
one was standard and at least the 67-72 trucks had a dual tone horn option with one high and one low horn. i'm not sure if the 61-66 trucks had the dual tone option.
totten
Re: Horn(s)
Post by totten »
I agree with 9mm. one is standard and i added one to my truck. MOUNTS BY hood release and should have wire hookup there too. Plug on and go.
bmcgc
Re: Horn(s)
Post by bmcgc »
Could someone post a pic of the horn on a 66 F100? I cant find a hole anywhere to mount this horn, and ther eis not one anywhere near the hood release. Im not even sure if I have the correct mounting bracket or not.
1966 F100 (Mine)
1965 Mustang (Hers)
1965 Mustang (Hers)
Wish List:
Win Indy 500
cavinandpavin
Re: Horn(s)
Post by cavinandpavin »
my truck is a 65 and i have no idea how original it is or if it been changed around but it has a horn mounted on both sides of the core support. you can see them from the front thru the grille.
i have a 66 grille and they are about even with the largest horizontal opening and just left of the "F" and just right of the "D".
No, its not a windsor or a cleveland, its a three fifty TWO!
Poppyred66
Cambodia
Re: Horn(s)
Post by Poppyred66 »
Have a look at the orientation of your "low" horn, which is on the right side. The optional "high" horn is installed in the same relative place on the left side. There are dimples in the rad support. Drill them out and use bolts the same as those you've got.
Eric
