I need some 1.25" outside diameter grommets. Every place local stocks up to 1" dia. NAPA was the worst. Said they had them, I asked them to verify the size, then drove there and they only had 1". So NAPA ordered them, turns out the guy ordered 1" grommets.
Has to be very close to 1.25". I need to protect wires and fuel line passing through a crossmember. Without breaking the bank. If nothing else, I will split some rubber line and run that along the crossmember pass thru hole.
where to find grommets?
- dotcentral
Re: where to find grommets?
- dotcentral
Thanks Slick 4x4. I will keep that in mind.
I went to Lowes after posting this and they had them for $1.29, so I bought one to try out.
which kind??
This kind?
Or this kind?
If you are looking for the first kind, look out for Wallace, and Gromit will be nearby:):)
haha....sorry, couldn't resist:)
This kind?
Or this kind?
- Brians1966
Is Wallace out getting some CHEESE !!!!!!!!!!!!
1966 F-100 LONG BED, 240cid 3 speed red and white, Red and White Interior with a Mossy Oak Seat Cover
2013 Ford F150 STX Supercab 5.0 litre
DETERMINATION: The feeling you get right before you try to do something incredibly stupid!
CONFIDENCE: Is the feeling you have before you fully understand the situation!
Mc Master and Carr, they have everthing!!
Doug
Doug
- dotcentral
Got some locally, thanks
