Fuel tank relocation
1965 stepside
Anyone done a fuel tank relocation to the rear
I have a spot to put it just curious how hard
It will be and is it worth it? Do you get any more
Room in the cab with tank gone?
- Total Gearhead
Re: Fuel tank relocation
Many people have used a Mustang tank. Search around a little you should find a bunch of info on it
aka "Horsepower"
61 F100 Step
"One Step Closer to the Edge!"
http://www.hubgarage.com/mygarage/TotalGearhead
http://www.myspace.com/totalgearhead
dub@thetotalgearhead.com
http://www.facebook.com/group.php?gid=214833125322
If it has a motor or wheels I'm in!
61 F100 Step
Hunter's 64
http://www.ford-trucks.com/article/idx/ ... _F100.html
This will give you all the info, our trucks have same frame width's, It's what i used as a guide .
Danny
Danny
Last edited by Hunter's 64 on September 23, 2012, 5:24 pm, edited 1 time in total.
- WrongBedDave
Ive got a Jaz poly fuel cell in my truck. Fits in the same spot as the mustang cell and has a 16 gal cap. I think you can get them on Summit but JAZ is a local company for me so I got it directly. The fill is center mounted on top so I fabricated a door to fit.
Dave
63 Wrong Bed 2WD : 302/C4, drip rails shaved, aluminum radiator/e-fan, 16 gallon fuel cell, "custom" gauges, 1000W sound system
Photobucket Album:
http://s1084.photobucket.com/albums/j413/davewave649/
Build Thread:
viewtopic.php?f=32&t=27105
Photobucket Album:
Build Thread:
you do not get any more leg room as the seat wil not go any further back but you do gain storage behind the seat you did not have before
1965 stepside
Thanks for the advise not sure if I will relocate
The tank yet I have a very little budget
But I did check out the links and printed off
Some info
Some info
William-in-St George
Not worth the effort IMHO. If you want more room for the driver invest in a tilt column, PS and a smaller steering wheel.
William-in-St. George
i would add the tank to have another but keep the original.
I will add this,
My tank is not in the cab, so I was able to build a different seat mount that DOES lean the seat back further.. taller stands up front than the rear. I got rid of the sliding mechanism as it seemed of no real use to me. I feel it does make for a nicer sitting position with a stock seat..
