What have you done to your slick today??
Re: What have you done to your slick today??
Bought a NOS water pump rebuild kit at DC for the 292. Broke a gear puller jaw trying to get the pump apart. Put that away and started working on my winch.
put my fog lights on my bumper and finished wiring up my cb radio.
- Total Gearhead
Motor/trans mocked up. Trans crossmember in place. Motor mounts mocked up outta cardboard. Not sure at this point of I am going to use the Pontiac frame mounts or the ford motor mounts. Tomorrow is another day
aka "Horsepower"
61 F100 Step
"One Step Closer to the Edge!"
http://www.hubgarage.com/mygarage/TotalGearhead
http://www.myspace.com/totalgearhead
dub@thetotalgearhead.com
http://www.facebook.com/group.php?gid=214833125322
If it has a motor or wheels I'm in!
61 F100 Step
worked on my slick for about 2 hours tonight. I first seperated the front stone guard from the core support and also the grill. Those bolts were a pita!!! i had to cut them like spliting a carrot then chisel the pieces away, then grind that end of the bolt...
eventually i got it, then I worked on removing some rusted metal with the grinder, and also worked on the front core support frame area, and the inner fender area below the battery.
frame rail
grill, stone deflector, etc...
core support and its rust
under battery box, inner fender
frame rail
- Total Gearhead
I didn't get a chance to do anything on the Ol' Boy today except plan out what I am going to do next. Tomorrow is not looking good either. But will be be back at it on Friday without fail
aka "Horsepower"
61 F100 Step
61 F100 Step
Installed water pump, thermostat, radiator hoses, fan belt and went for a ride.
- WrongBedDave
Finally got to drive the truck for the past few days after all the time with the truck torn apart for wiring and what not. Today i mocked up a switch panel for the headliner so I can finally wire and install the stereo and switches. Once everything works well I'll have to figure out how the heck im gonna upholster that headliner.
Dave
63 Wrong Bed 2WD : 302/C4, drip rails shaved, aluminum radiator/e-fan, 16 gallon fuel cell, "custom" gauges, 1000W sound system
Photobucket Album:
http://s1084.photobucket.com/albums/j413/davewave649/
Build Thread:
viewtopic.php?f=32&t=27105
Photobucket Album:
Build Thread:
3:30 am - check oil, set choke, listen the the 352 work its way up to temp while packing a lunch
3:35 am - pull out of the driveway, listen to the 352 sing a 45 minute aria on the way to work.
4:20 am - slick takes a 15 hr lunch break
7:15 pm - listen to the 352 sing another song on the way home, they sound a lot alike but I like 'em all.
William in LA (Lower Alabama)
1966 F100 SB - 352/3spd
1965 F100 SB CC - sold
1966 F100 SB CC - sold
1966 F250 Work body - sold
1967 F100 SB CC - 360/C6 - sold
1971 F100 Long Flareside - 390/4spd - sold
1972 F100 XLT Ranger - 360/C6 - Gramp's old truck
Plus '53 CJ3B, '54 CJ3B, '67 CJ5, '70 Jeepster, '71 Jeepster
drove it
had to make a little trip just under 50 miles total
got to go up and down some 6% grades
4.56 gears make it easy
filled up the gas tank and got some paint for my back bumper.
might paint it later on if the wind dies down.
- Uncle Skip
Harper. My inner fender wasn't nearly as bad as yours but it did have a big honking hole in it. So I cut the hole square and built a battery box to put in the hole. Worked out pretty good.
When you get lemons, make lemonade. If you get S*it forget the S*it sandwich's and go find another inner fender.
This is the original engine compartment.
Here is the new version and the rewiring components.
The battery box makes a neat place to store parts when you're working on "stuff".
That battery box makes an EXCELLENT tool box Skipper !
I like that uncle Skip....
today I removed the insulation out of the interior, along with the windsheild wiper motor/hardware, all my switches out of my dash, the rest of my wiring from under the dash, removed the pedals, clutch rod, brake booster, heat box/motor/duct work, vent boxes, (everything except the windsheild and back glass) this thing is almost ready for the blaster....
oh and I picked up all of my other parts from the blaster...
800 miles of rain and the towtruck is at the shop! The borrowed trailer was just slightly too narrow for the duals, and just slightly too tall for the truck bed. Removed one outer dual, enlisted a convenient fork truck to lift the rear of the bed to clear the rear sides of the trailer, and presto, a great fit with good tongue weight. We headed back to Tejas, checking tire and bearing temperatures at each stop. One tire had been consistently slightly hotter than the others,but of little concern, since all four appeared to be quite new. This one had a different thread design than the others. My son checked the tires at a stop abouit 100 miles from home and noted the tire felt somewhat "sticky". A pressure check indicated it had dropped to 30 psi. Since neither of us particularily wanted to unload everything in the rain to get to the spare and install it, we slowly progressed to the next town. By that time a bulge the size of a football had formed on the inner sidewall. One new tire later, we made it on back. While unloading the truck, I evidently got up against a sharp edge on the trailer side, blowing out the one new tire on the towtruck! Oh, well I have a pretty good matched set somewhere.
Since it's supposed to continue raining here tomorrow,and I need to rest up instead of tackling split rims, I will probably contract out the tire swapping.
After 10 months and 1300 miles (900 under it's own power), at least the towtruck is home!
Now I've got to fix all the new problems by next Friday (as well as make a living), since a local chamber of commerce is sponsoring a car show Saturday, with the Friday night prelude being an outdoor, drive-in type showing of, guess what well-known car- related animated film
I put my tailgate and homemade roll pan on this morning... Still need to put the emblem on the gate, trying to decide on the black or silver one from DC.
Also cleaned her up a bit.... Almost to the "done" stage!! At least thats what I tell her.... Lol
removed my back glass, and am in the middle of the door glass passenger side removal ...
Yesterday I put a Pertronix ignition in it. Today I drove it for the first time in a couple weeks.
Started header and steering mock-up!
Moved ballast resistor to BAT side of coil and ran a (temporary) wire from solenoid to coil. Went back to 5 psi electric fuel pump. Tow truck sounds much healthier now, but unable to test drive until tires are swapped. Sprayed some degreaser in the general vicinity of the engine compartment, too rainy to get serious about it.
Cleaned the outer face of core support on 61 prior to grille re-installation.
Started on pattern for gravel guard for 65 long bed, but soon rained out.
- WrongBedDave
Took a nice long drive in her last night for no reason at all. Shes running much better now with the new MSD dizzy and what not. And its amazing what a difference the new harness made in how bright all the lights are.
Dave
Photobucket Album:
Build Thread:
Photobucket Album:
Build Thread:
received in: bed end cap for Matthews flareside today! hopefully this weekend he will help me put the boards in.
