Got most of the kinks worked out of the front clip.
The hinge bottoms were hitting the pinchweld and wouldn't let us adjust the hood down far enough.
After:
The radiator support was too high, so the fender didn't fit right and the hood ran uphill.
The fender also didn't fit the shape of the door edge, so we had to flatten it.
After standing on it with the inner brace supported top and bottom.
Hood adjusted/bent to fit flush with the cowl.
The fender to filler panel fit was horrible, paint would have chipped as soon as the bolts were snugged up.
After straightening the gap out.
Driver side fender gap. Needs to be opened up a hair at the top.
Hood damage.
Bumper slots in the filler panel didn't line up, even though the bumper fit perfectly with the holes in the frame horns.
Fender and filler panel corners stuck out past the hood edge.
After cutting and reshaping.
Frame/engine protected from welding splatter with a fiberglass blanket.
Found some pinholes in the hood edge so we cut it out.
New piece welded in.
