More work finished. I welded in a solid front piece so that it would be straight. I also cut through it on each side so that it would be cut out around the sheet metal ribs on each side. I cut the center back out so I could weld it back in with the drop necessary for the corrugations in the truck floor.
It needed a 1/4 inch drop, so I welded a spacer made from angle scrap on each side.
On the center piece I cut out the pieces that would cover the ribs and become crap catchers.
I then welded the center back in. I clamped it and did some plug welds so that I would not have to keep clamping it.
