All ford parts, and they even clear the old rims.
Do the one ton trucks use the same 8 lug hubs, with 6 lug adapters?
If so this may work for tonners too..
FarmMotorSports wrote:Do the one ton trucks use the same 8 lug hubs, with 6 lug adapters?
See...WTH don't the f100 kits use ford calipersFarmMotorSports wrote:I'm one step closer to having the Uni at SS.
I used 9/16 studs... the key is knurl diameter and the knurl reaching thru the rotor to the hub. Size 1/2" or 9/16" is your choice. From there it is almost straight forward. A 3/8" plate cut to match my template. Plate bolts on after the steering arm so a 1" spacer is needed for the top fasteners. Those fasteners will need to be longer thanks to the 3/8" plate.
When talking about off-the-shelf conversion kits, the reason is the way the caliper mounts. The GM calipers bolt on which means a simple bracket can be used. Ford calipers use pins which require a more complicated bracket. Simple is cheaper than complicated and people generally prefer cheaper therefore, GM calipers are used in kits. As far as the actual function goes, there is no difference, so you get the same performance with a GM caliper based conversion for less money.aj64f100390-292 wrote: See...WTH don't the f100 kits use ford calipers...really bugs me..Ill do it eventually..and NO backing plates...not trying to hi-jack the thread though
Nice job looks good
Well that part I got..Idk I guess I just like being able to walk in and order a ford part..and know its ford..because.then agian most people unless they knew they're cailpers brand designs...would kniw I suppose. so the f250s are easier? But in the end I may just suck it up buy the kit..lots of other things I need to work on other than that..charliemccraney wrote:When talking about off-the-shelf conversion kits, the reason is the way the caliper mounts. The GM calipers bolt on which means a simple bracket can be used. Ford calipers use pins which require a more complicated bracket. Simple is cheaper than complicated and people generally prefer cheaper therefore, GM calipers are used in kits. As far as the actual function goes, there is no difference, so you get the same performance with a GM caliper based conversion for less money.aj64f100390-292 wrote: See...WTH don't the f100 kits use ford calipers...really bugs me..Ill do it eventually..and NO backing plates...not trying to hi-jack the thread though
Nice job looks good
