Ford 262 vs 223 interchangeable parts?
Just trying to get some information on the 262 six engine. From what I understand, it was a heavier duty version of a 223 (obviously having a different bore or stroke) and I believe used timing gears instead of a chain, I'm wondering if the 262 gears will fit into a 223 or if any other parts will interchange? The more info the better. Thanks
-'61 F100 short box flareside (classic street rod) 223, 4spd
-'62 F100 long box unibody (murdered out) 460, C6
-'66 F100 long box flareside (original) 240, 4spd
-'64 F100 long box styleside (pro-street) 307 GM, 700R4
-'64 F100 long box styleside (daily driver) 223, 3spd
-'65 F100 long box styleside (original) 240, 4spd
-'66 M100 long box styleside (sold) 240, 4spd
-'64 F250 long wrongbox styleside (sold) 292, 4spd
Re: Ford 262 vs 223 interchangeable parts?
Here's a link to some info ...
Sounds like its a no-go because of cam difference
Changing a chain on a 223 is about as easy as any engine
I myself wouldn't think it would be worth the swap
https://www.jalopyjournal.com/forum/thr ... 62.700564/
Thanks, that's the info I was looking for. Looks like I would have to change the cam as well to get the gears to work. I've changed a chain, just wondered if gears were an option.
