went to the cruise in at the local church on
Saturday/
Took the truck for a bunch of little trips around town. you can see the steering wheel is cocked to the left-
Took it to Ford to do the alignment. nice and straight now.
Best it will be without bending up the straight axle.
Nice and tight now.
my shipwrecked '63
Re: my shipwrecked '63
I spent some money (not spent on port calls in Australia or Fiji etc) on the speedway disc brake set up. I originally didnt intend to do this mod, but after driving around town a bit, people here are stupid and i had to slam on my brakes a few times to avoid a collision. Put stick shift and drum brakes back on every car and we wouldnt be having texting and driving or people riding your bumper as much.
I bought the front disc brakes, a 9" rear bolt on set, a booster and a 1 1/8 bore dual master cylinder.
Anyway,
I started the other day, and ran into a few problems, but were solved with a little time and a few dollars.
removed old front brakes and backing plate.
Installed the bolt on bracket. Had to enlarge the spindle bolt holes ever so much with a drill bit. It even says to do this in the instructions.
Use the long bolts in the bottom two holes, and shorter bolts in the top. be sure to put the spacers in.
The kit supplied the outter race that needed to be replaced. the one already installed needs to be popped out and replaced. (instructions also state this)
my original 15" innie wheels do not fit over the hub. I had to add a spacer and added longer studs. the studs I put on i got from Summit. 1/2x20x3" with a .625 knurl. The local parts houses are stuck on "what vehicle is this on" and don't understand. Just save yourself the hassle and buy it online.
Caliper has a nub in the casting that has to be ground off to clear the spindle bolt that holds the bracket on.
Once you mount the caliper, you need to check movement, and adjust the stopper bolt.
mine is seized and I had to hit it with a torch, a bunch of wrenches and hammer it. F- its feelings!
adjusted
everything clears.
mounted tire, and with longer studs and spacer, it still clears the hub cap.
Repeat on the other side.
Hook up the brake hoses. I am working on the rear now.
Anyway,
adjusted
everything clears.
Looks good April. It's always good to be a little safer.
Are you going with a power brake master cylinder?
yes. I bought one. Haven't installed yet. Forecast called for rain all day, by 2 it still hadnt rained so i fee like i wasted my entire day. so I went out and took a look at adding a trailer hitch. But wait- there's more!
Knocked myself in the face with a C clamp this afternoon mocking up my tow hitch. gave myself a black eye.
OUCH!!
Sorry to hear about the black eye!!! But the brake work looks great and you won't regret doing this upgrade. I never was crazy about the single acting wheel cylinders on mine just driving it around in the yard. Glad you are getting some time to enjoy your truck, been alot of work to get where you are
weirdly enough i had a harder time with the rear wheel disc brakes then the front. i still need more daylight and sunshine to finish hooking up the ebrake cable (using my original ones which were brand new).
my back is jacked up, my shoulder is jacked up, and with the bad back lately, i can't spend a lot of time on the concrete under the truck.
I did install the trailer hitch. need to finish wiring the pigtail.
not a fan of how the license plate is mounted now because it used to be below the bumper in the middle. I moved it to be below the driver rear light because it has the white license light. I added a silicone plate protector to it and bent the plate mount.
spent some nights puttering around the 1:25 model kit I bought a long time ago.
next part of my summer project is building a canned ham camper based off this:
Ican tell ya since I started working on rear brake disc conversion, the speedway kit doesn't work for stock innie wheels. I am waiting on 1" wheel spacers to help. The caliper will hit the inside of the rim no matter how much you grind off the caliper. What a pain in the ass. Bending new brake lines as I can. My back hurts a lot so it's slow going down there.
Need to figure out my stock steering wheel horn issue, doesn't work when i out wheel back on, but I can sound it when the steering wheel is off.
