a little work and alot of ?'s
Anthony
well it is finally warm enough to work outside, a balmy 45. (comfortably Iceman) so I got the front driprail/windshield area cleaned and to no surprise found more rust. can I just fill this area with filler and sand it down or should I be doing something different? I am thinking of filling the seam line around the back of the cab also. Is this a good idea? I can cut out and weld in patch panels and such but in the area above the windshield I am not comfortable to do. I am open to any tips and reccomendations. I just need some feedback. thanks guys, Anthony . [albumimg]5509[/albumimg] [albumimg]5504[/albumimg] [albumimg]5505[/albumimg] [albumimg]5506[/albumimg] [albumimg]5507[/albumimg] [albumimg]5508[/albumimg]
I would weld patches in if it were me.
Filling the rear seam, shouldn't cause a problem will just look cleaner - I'm doing mine.
brian gilbert soares
Anthony
OK I know that welding in new is the way to go but I am not a welder and do not know how to weld in such a small area that I can not get to from the inside of the cab. (pic #2 & #5) that is a seam and I don't see how to put my pigeon poop welds in there without making more trouble for myself. any hints on getting this welded up? Oh by the way, on a positive note, I got the pass side lower hinge panel cut out, just need to get it welded in. [albumimg]5510[/albumimg]
thanks . Anthony
Anthony
Anthony,
Here is a pic of the rear seam welded in.
Welding that in was quite a bit of work but it was worth it. I thought about shaving the driprails but mine were in perfect condition so I thought better and didn't do it. If I had to repair the rust on yours I would probably shave them. I think they would look nice without the driprails.
Kevin
Kevin
kstones63
63 F100
29 Ford Sedan Delivery
99 F250 PSD, 4x4, CC
95 F350 Flatbed Dually Diesel
63 F100
ELpolacko had some pictures of the drip rail removal and the mods done to his uni, not sure which site had the pics, but I got one that shows the mods done after priming.
http://fordtruk.com/forums/album_pic.ph ... ser_id=201
I think the others are on the old site.
Dean
Dean
61 Mercury SWB Uni - Project
63 Ford SWB Uni - Parts truck
- DV65CustomCab
re: drip rail underside rot. Welding is best, but if you can't do that don't use filler. It will blister out again. I would use epoxy instead. More impervious to moisture and rigid. May ask your local auto body supplier if they have something specially made for that. 3M makes all sorts of wacky products.
Stop The Longbed Hate!
Now: '93 F150 Lightning
Anthony
I found these on the net. [albumimg]5517[/albumimg] [albumimg]5516[/albumimg] I am going to try and stop by the local auto body supply today and see if he has anything epoxywise that will work. I think I prefer the looks of the driprails on rather than shaved, but I would do it if it was the last choice, I guess. (I don't feel that I am a good enough welder to weld the cab all the way across. there would be alot of grinding.
) thanks for the pics 61 merc and kstones63. I appreciate all the help. this has been a long journey and I'm glad I found a support group.
Anthony
Anthony
The rust your pix show, were it me, I would go the route of all the drip rails removed. Even tho it makes for a lot of welding I think the results would be well worth it. If you take your time and do small sections at a time it should come out good. Trust in yourself some, ask a lot of questions and you will do fine.
Looking at the pix of all the drip rails removed I really like the look. It modernizes the truck very nicely. I just might do that to my 62 UNI.
Anthony
Well, since I like the looks of the drip rail on my truck I decided to use fiberglass mat/resin and fiberglass resin jelly. the auto supply guy said that if done right, the fiberglass resin jelly will work. ( I hope I did it right
) I did go one step further and mixed up the resin and mat and stuffed into the front where the holes were from the inside. Boy, was that hard to get to. any way just thought I would update everyone on my decision and progress. ( more in build section http://fordtruk.com/forums/viewtopic.ph ... c&start=20 ) thanks for the support when I needed it,
, I think this place is one of the big reasons I keep going on this truck sometimes, but I know that with the help on here I WILL GET IT DONE!!! thanks guys, Anthony [albumimg]5562[/albumimg] [albumimg]5566[/albumimg]
- 64low-n-slow
Anthony
Thanks low-n-slow for the tip, I really hadn't given much thought to the inside. the truck is completely stripped out so it should be easy to do. will undercoating be better than paint? This is the first truck that I have done that I am attempting the whole thing myself. Slow and steady wins the race (First On Race Day). I usually average 5 years on the trucks that I drive and redo and I am on course to top that by getting this one done in about 3 1/2 years.
but I am not driving this one, big difference. thanks again, Anthony
blackagatha
Anthony
