Help.
I'm not a Y-block expert and I need to make sure that the dual exhaust manifolds I have will work on a Slick. They are the rear exit types like on a regular passenger car.
I know the rear motormounts are on the bellhousing, so would they interfere with the exhaust pipes?
I think they should work, but maybe not............................
Any comments before I sell/ trade them to a fellow Slickster?
U@ss
Y-block guys. ??????
- Uncle Skip
Model_T_46804
Manifolds
Skip,
They won't work on a truck, they'll hit the firewall. You need rams horn manifolds, they dump the exhaust out in the center of the manifold, not the rear.
Jim
Jim
- Uncle Skip
Pure Country
y blocks
If you want to run duals on a truck and can't get ramhorn manifolds you can buy y block headers. Reds Headers sell them and they have their own website so you can find exactly what you want. It is one of the best things that I did to my '61. I used to have the wrap around exhaust and now have true duals.
Johnny's 61 F100 292 & 3 on the tree
Model_T_46804
manifolds
Jakdad,
If you mean will the car manifolds work if you have a floor shift.....No they won't, the exhaust will not clear the firewall.
Jim
Jim
Okay, You can use the right manifold, If I remmember right. The left manifold is the problem, because of the Z-bar linkage. I've thought of flipping the stock left manifold and it could work, but makes for a funny angle bend on th down pipe. I've also seen the left dual exhaust manifold cut and rewelded at a diffferent angle. Moving the Z-bar helps also. It might work if the Z-bar is removed and you install a hydraulic clutch release system, whic was available but generally not used on half or three quarter ton pickups. Mainly on big trucks. If interested, There is a used setup on Ebay right now from Owogeny. There is also one new original stlye slave cylinder on Ebay at this moment for 12$ starting bid, and I know of one seller that has two master cylinders in his store for 25$ each. You would have to improvise on some of the hardware on the new stuff, but it's do-able. I think the firewall is not the problem with the duals. Also, I have three sets of ramhorns at the moment . One nice set, one decent set has had some repairs, and one set that has cracks.
1961 F350
1964 Galaxie convertable
1965 Ranger, and shortbed
1966 long bed, and shortbed
A few parts trucks also
1991 Capri
2011 F250
2004 Lexus
1991 Capri
2011 F250
2004 Lexus
Guys, I have several sets of different y block manifolds, and not all are the same on the duals. I retrtodesign to fit. Linkage is fairly easy to change around, most times.
1961 F350
1991 Capri
2011 F250
2004 Lexus
1991 Capri
2011 F250
2004 Lexus
