Greg's 62 Uni long wheel base
tschmitt
Post by tschmitt »
Lookin good so far
kstones63
Post by kstones63 »
Greg, it is looking good. All of those things take a lot of time but are definetely worth all the effort when done.
Keep up the good work.
Kevin
kstones63
63 F100
29 Ford Sedan Delivery
99 F250 PSD, 4x4, CC
95 F350 Flatbed Dually Diesel
I am pretty pleased with the A pillar - there is no body filler in it - all metal.
One issue with the shaved drip rail I have - the cross section has a slight down roll up under neath. It is quite thin right at the edge and it needs a small rounded shape to match the B pillar edge at the door opening. I may have to run a bead up under it to thicken it there so it has some more material before it's shaped. I am going to finish it all the way to the A pillar before I mess with it though.
I can't shape it well with the drip rail in the way. Depending on what angle you are welding from and even with a 3" grinder pad you would be surprised how much that 1/2" of drip rail can be in your way, lol.
When I am done cutting and welding I am going back along the outside with a flat copper spoon and some wire to get a smoother edge to work with too. I may hold the copper spoon against the outside to weld up underneath. The spoons are really nice for helping control a weld you want to hold a shape.
This is all structural welding of the shave now, fill welding will be done after.
It is pretty tedious work but I am enjoying doing it. Gluton for punishment? LOL.
Thanks Guys.
looks good.
more work than i want to do on mine for sure.i will glad to fix everything back to the way its supposed to be without adding more to do
A bit more work on the roof today.
I got the antennae hole filled too. That was a fun piece to cut - the hole may have been cut with a hacksaw, lol.
Anthony
Post by Anthony »
lookin' good Greg. I filled my antenna hole with a washer, but then again mine was round... :lol: Keep us inspired...
Anthony
Greg, you are certainly a man on a mission!, keep it up! , great work!
jwh f-100
Post by jwh f-100 »
Looks great Greg!!
You gonna close up the cowl vents??
Jason
Beer will change the world.
I don't know how but it will.
I actually hadn't even thought of that Jason - Hmm.
The goal of my smoothing, I don't want to change the character of the truck - just accentuate it. Guess you could say I am making my Slick a little more slick (I know - bad pun).
If I fill the vents I will need to replace them somehow - not sure how I could do that and hide it. I would also need to address the wiper pockets too then. I'll probably just leave it, I have to finish the roof before I do anything else too.
Nothing done since Saturday now, I will get back to it this week though.
Thanks for the comments guys.
Still jumping around on my paint scheme too - I came up with a different scallop job I like too. I may save that one for a 64 shorty though.
I am also considering the same paint job in different colors - don't want to spend $500 + on paint.
Finally warmed up enough this weekend for some more work. No pics - just more of the same on the drip rail. I at least got the "bad" part done - made it far enough over now I can do the rest not having to sit in the windshield frame.
Reds Rod Shop
Post by Reds Rod Shop »
Good progress. A friend of mine has been encouraging me to shave the drip rail on my 64. I just wasn't sure what it would look like. From the looks of yours, I like it. Keep the pics coming. I can't wait to see it finished. Red
Red, IMHO I wouldn't likely shave the drip rail on a 64-66 unless I swapped out for the 61-63 roof. The raise in the later roofs would stand out too much I think. The earlier roofs have a nice smooth blend that is interrupted by the drip rail. It's you truck bro - I was giving you some food for thought.
BMJ's 65
Post by BMJ's 65 »
Looking good Greg. I was up your way today, but had a full plate. Kinda nice having a little warmth this weekend.
What's in the garage at any given moment?
FE powered Bump
93 Lightning
66 Slick strewn all over the place
08 Taurus
13" Huffy W/ training wheels
I got the rest of the drip rail off and at least welded together today. I will need to do some more fill welding but this the last I will do until I have a C 25 tank sometime this week.
I also cut up under the back 6" of the roof cap and a slit in it over the roof seam. It stuck out too far due to a bad fit from Ford. Cut it, reshaped it, clamp, tack, and then went back up underneath and filled it in. I went ahead and cleaned it up a little with a flap wheel on the grinder.
I am probably going to have to add a filler plate over the door. The drip rail actually drops down a little past the roof so the gap is too wide at the top now.
I got the seam in the drivers side A pillar welded up too, still needs shaped. I hope it comes out as nice as the other side - it needed no fill.
It still needs some fill welding, and finish work but at least it gives an idea how it will look done. Should give a nice clean, smooth roof line after the glass is back in.
I even took some pics this time, lol.
As you can see I have been using the hood as a table while doing this. The floor pad section was a real help while sitting in the windshield to work most of the front. It also made it easier to not damage the dash & cowl my fat arse, lol.
weezle
Post by weezle »
Looks good Greg...I imagine it's quite the task to operate air tools right now, huh? Judging by the winter gloves on the hood, lol. :D
Matt
1966 F-100 352 3-speed
2003 F-150 FX4 5.4L Auto
LOL, those were left there last weekend - was out blowing snow. I have stuff sitting in the cab that has been there for 3 months including some tools still in the packages. One of these days I need to straighten things up out there. After it gets nice enough out I am going to put the Truck outside in the drive and rearrange the garage.
64low-n-slow
Post by 64low-n-slow »
Very nice work Greg. Keep it up!
oldtrucks
Post by oldtrucks »
Great work Greg looks real good. I've been thinking about doing the same thing to my 62 and now thinking is over and that is what I'm going to do. On the forward upper door corners I will radius them too. Have you thought about doing that?
When we did the 61 I filled the extention seams with braze you can get them flush and don't have to use much filler. I used lead to finish the seam off. They came out really good.
I'll use lead to do all my seam finish work so I don't have to worry about bondo cracking. I really like to use led as much as possible, learned how to use it when I was a teenager in the body shop I apprenticed in.
Mike Kincheloe
Mikes Old Trucks
I restore old trucks and cars
1950 F7 Cab and Chassis
1976 F150 4 Speed 4 X 4
1996 Taurus
kstones63
Post by kstones63 »
Greg, It's looking good. Think about "oldtrucks" idea of doing a radius on the front corners of the doors. That would look great especially with the drip rails gone. I wish that I had thought about that.
Kevin
kstones63
63 F100
rwhistles
Post by rwhistles »
your doing a great job Greg, wish I could weld half that good.but still Idont think I would ever attempt to do what you are doing. just keep it up.
1961 F350 pick up
1962
1963
1964
1965
1966 F350 camper
