anybody used this type of 'sand blaster'
has anyone used one of these type of 'sand blasters'
the disadvantage i can think of is flash rust with the water
the advantage would be not needing a big air compressor
disadvantage would not be able to 'reuse' the sand
advantage would be not create heat
http://www.northerntool.com/webapp/wcs/ ... _200322963
Fordman
Post by Fordman »
i'mnot sure i like it. but i have never used one like that though.
Pretty cool if it works. I would almost think it would be messier than a conventional one though. Metal prep will take care of flash rust which you would have even without the water - just not enough it to see.
Post by Gritsngumbo »
I was talking to a guy the other week who has something similar to that (I guess) and uses soda. He works in the oil and gas industry and uses this for some of the equipment. Haven't been able to get in touch with him again for more info or to "borrow" his rig.
Pro-Street/StateTk
Post by Pro-Street/StateTk »
I don't know about that one , but years ago I used to use a 5 gal roll around craftsman,
and for ( Small Jobs ) I really liked the ( Cheap Bucket blaster ) instead of the better one.
The Bucket baster used to cost about ( 20 dollars ) and it sucks out of a five gallon
bucket , they sell them every where ! Try one .
P.S. make sure you wear ( Breather and Ear Plugs )
Wally Womack
Pro-Streeting Ford Truck's with all stock Ford parts since the mid 90's
PFM-64f100
Post by PFM-64f100 »
I used the Medium duty sand blasters from this place. http://www.ultimatewasher.com/sandblaster.htm
I blasted my frame under the 64 and it worked out good. There was a little flash rust but I used the blue lightning metal prep and it took care of the flash rust. worked out good just don't use it when wearning shorts... :twisted:
