I am attending the school of "hard knocks" and also learning that my brain is "f-up". After a kid in the classroom did some damage to my head (older post I had about the assault I received in the classroom) after 3 weeks I finally realized I am having some problems.
Thank god for my wife that is a nurse to help me realize I was having issues.
At least I realize things could be worse and life is too short to worry and I am moving on
Funny story I started out with a simple oil change, but then I decided to change the oil pan gasket because of what looked like oil seepage around the pan and engine block. Well after finally figuring out I had to raise the engine to get the oil pan out I couldn't slide it forward because my jack was in the way. I kept reading the chilton manual and trying to slide the pan out through the back because of the cross member.
A day later I thought and realized put blocks under the motor mount, then move the jack and block from under the damper. I still couldn't get the pan out.
Next day I wedged myself under the truck and saw an oil pump and flow line (I think it is called that)
today I will start her up and check for leaks.
Laters-Mr. D
