Aluminium grilles
GDG
Aluminium grilles
Post by GDG »
Any tips on polishing an aluminium grille? Mine has some small gouges, scratches and oxidization. It is in fair shape and I would like to use it but it needs a good clean up. So far hand polishing has been a slow process. Any tips on polish, or buffers, etc, I'm thinking of a Foose power ball or something like that.
Doug
DV65CustomCab
Post by DV65CustomCab »
Did you remove the anodizing first? That's the first step.
Stop The Longbed Hate! :)
Now: '93 F150 Lightning
Red66
alum grilles
Post by Red66 »
Wet SOS pads work good.
fseries
Post by fseries »
The previous owner of my truck used a blast cabinet with the pressure set at around 60 psi to remove the anodizing. Im not sure what media he had in the cabinet but something like smooth glass media would probably be best. I am pretty sure he polished it by hand after getting all the anodizing off.
66 F-100 Shortbed 2wd
78 F-250 Supercab 4x4
87 F-150 Supercab 4x4
And a bunch of other stuff.
Fanatic
Post by Fanatic »
When I polish raw alum. I use a small disc 4 1/2 " that has that stuff like scuff pads on it. Get and xtra fine one then use a buff pad and compound. I have recently found that Meguires Ultra Compound works REAL nice.
GDG
Post by GDG »
Some of the anodizing is already off. Sounds like it will take a lot of elbow grease to get it down to bare aluminium!! What do you coat it with to keep it bright?
Doug
64low-n-slow
Post by 64low-n-slow »
Eastwood makes a stripper for the anodizing (wish I'd bought it) for cheap money. After you get it off, then use sandpaper to smooth the defects. Finish to 1000 grit, then polish with rubbing compound, machine if you have a small buffer, otherwise it takes a LOT of elbow grease. To protect your hard work, POR 15 makes a clearcoat for aluminum. YOu MUST use their metal prep first (they don't mention it in the ads for the clear). And follow the directions TO THE LETTER. It works great if you do this.
Hope this helps
Anthony
Post by Anthony »
O.K. guys, so do you think that if I took the anodizing off of my grill the etched stains from the PO that cleaned it with I'm guessing aluminum coil cleaner (for A/C's) would disappear so I could polish it and use it??? Any ideas???
[albumimg]5249[/albumimg]
64low-n-slow
Anthony,
I'm pretty sure your grille will clean up.
BikerDude
Post by BikerDude »
When you get your grill (or any other aluminum for that matter) polished to the point where you are happy I suggest using Zoopseal to make it last. I used it on some aluminum valve covers and it was easy to use and is advertised to last 2 years. Kind of pricey but it's better than polishing all the time. Got mine at Summt Racing.
