Recently my truck was sitting still and idling and then just quit running. The engine is turning over but it's not getting any fuel. For as much as we were pumping the gas it should've flooded the engine. However it didn't, you couldn't smell any fuel.
My guess is that this is a Fuel Pump problem? Am I correct in my deduction? Could it possibly be a fuel filter just clogged?
I'm betting I'll just have to replace the fuel pump. Any suggestions on a good brand or good place to get a good quality one?
Thanks!!!
Fuel issues! NEED HELP!!
Anthony
fuel issue
First thing I would do is pull the fuel line at the carb and then have someone crank it over. If you've got fuel then it's the carb if not then go on to the filter or the pump. Before I would change the pump I would pull the fuel line and make sure that the line is not plugged. Just my thoughts.. Good Luck
Fuel!!
If you are getting fuel to the carb you might want to check your accelerator pump on the carb.
I had this problem with mine just the other day. (Had a rip in it)
I thought I was wrong once...
Turned out I was right!!
Russell
Russell
- "Whitey Ford"
